WIRING
I HAVE A 90 4DR AND IT WAS FINE...BUT I GOT AN ELECTRICAL PROB I..AND I CHECKED ALL THE FUSES AND MAIN RELAY..AND MY ECU SAYS EVERYTHINGS FINE..BUT..FOR EX: IF I OPEN MY RIGHT SIDE PASSENGER DOOR...THE STEREO GOES OFF...I NEED SOME IDEAS..
THANX
THANX
The ecu and main relay doesn't have anything to do with the stereo. Sounds like you have a short to ground through one of the speaker wires. If it does it every time, check it with a multimeter to confirm that's what it is. The wiring runs through the rubber boot between the body and the door.
