93 Integra Trunk area leaking problem
Old Jan 11, 2006 | 11:08 PM
12secteg's Avatar
Default 93 Integra Trunk area leaking problem
I have a 93 integra gs and the trunk has been leaking for a while, not to bad but recently its really been getting bad. I read on a forum a while back that theres some seal on each side of the rear bumper mount that might be cracking or deteriorated. Please advise thanks
Old Jan 11, 2006 | 11:17 PM
Rikter's Avatar
Chances are it's your tailight seals that are leaking. Easy to replace (pop out tailights, swap gaskets, re-install). Another way to find out where the water is comming from is to take apart your truck's interior, put a small friend inside, close hatch and then use a hose on your car and have the guy inside look around to see where the water is comming from.
-Rik
Old Jan 12, 2006 | 08:31 PM
tttravis's Avatar
Default Re: (Rikter)
easier solution- i waited until it was full of water took a drill and really small drill bit, drilled in the middle of the puddles, no water since
Old Jan 12, 2006 | 08:42 PM
projectTeG's Avatar
Default Re: (tttravis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tttravis &raquo;</TD></TR><TR><TD CLASS="quote">easier solution- i waited until it was full of water took a drill and really small drill bit, drilled in the middle of the puddles, no water since </TD></TR></TABLE>
yup and open your car up to get cancer....good idea
you tail-light seals could be toast, if you have a sunroof look to see if the drains are cloged
Old Jan 12, 2006 | 10:13 PM
SOHC_me's Avatar
Default Re: (projectTeG)
very bad idea to drill holes, its your tail light seals, 90% sure, i just replaced mine a couple of weeks ago, took like 20 min
Old Jan 13, 2006 | 12:52 AM
Backk InTheDA's Avatar
I hate everything
Default Re: (dc_mike)
Yeah, to look at the drain tubes, you need to pull off the back interior panels.
But, as a heads up, I thought I had a trunk leak as well. Because I saw which probably was a trail of water, and my back floor behind passenger seat was sopping wet. Then to relize, my passenger side airduct was the problem.
So I was looking at the wrong end of the car the whole time .
Just something to consider, what year is your integra?
Old Jan 13, 2006 | 01:01 AM
ZipTieGUy's Avatar
same prbolem here, i know its my tail lights, but im gonna drill a 1 inch hole anywyas, why because im lazy
Old Jan 13, 2006 | 01:07 AM
I hate everything
Default Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy &raquo;</TD></TR><TR><TD CLASS="quote">same prbolem here, i know its my tail lights, but im gonna drill a 1 inch hole anywyas, why because im lazy</TD></TR></TABLE>
I really hope your joking.
Old Jan 13, 2006 | 01:32 PM
91IntegraX's Avatar
1 inch......jezus that like big enogh to make your trunk home to every moush and small rodent and bug in the city...not to mention ittl give it cancer faster then road salt
JDMx05
Sep 10, 2011 08:02 PM
Pandahatch93
Dec 16, 2006 07:11 PM
tcontesh
May 2, 2006 07:08 AM
kwoksturr
Oct 10, 2004 05:08 PM
civic 93
Mar 4, 2004 08:44 PM
