DPIF TO MPIF
Old Jan 11, 2006 | 09:22 PM
xisda1's Avatar
Default DPFI TO MPFI
I BOUGHT A CAR FOR PARTS I'M DOING THE DPFI TO MPFI FIGURED ID NEED TO SWITCH THE MAP SENSOR/PURGE VALVE HOUSING AS IT HAD THE EXTRA HOSES COMING OUT THAT I NEEDED, THE NEW ONE HAS A DASHPOT CONTROL SOLENOID VALVE(DPSV) AND MY PLUG ISNT MATCHING UP. FIGERED I WOULD JUST POP SOME PINS AND PUT THEM IN THE NEW PLUG LEAVING THE DPSV UNHOOKED IS THIS A GOOD IDEA? OR SHOULD I MAYBE TRY TO HOOK IT UP BUT TO WHAT NOT SURE IF IT WILL WORK WITH THE ECU IF ANYONE KNOWS ANYTHING GIVE ME SOME INFO AND WHAT THE HELL DOES WITH CATA AND WITHOUT CATA
Modified by xisda1 at 3:51 PM 1/12/2006
Old Jan 11, 2006 | 09:31 PM
crxnj's Avatar
Default Re: DPIF TO MPIF (xisda1)
MAYBE THIS PICTURE WILL HELP YOU..GO TO THIS WEBSITEl FOR THE ENTIRE MPFI CONVERSION WRITE-UP
Old Jan 12, 2006 | 09:15 AM
badboyr66's Avatar
Default Re: DPIF TO MPIF (Mr.speaker)
Try posting without caps... everyone will think you are yelling
Old Jan 12, 2006 | 02:56 PM
xisda1's Avatar
THANKS FOR THE SITE I,VE ALREADY BEEN USING IT. NOW I FINISHED THE SWAP AND THERE IS NOTHING WHEN i TURN THE KEY JUST DASH LIGHTS. ANYBODY ANYBODY GOT ANY ADVICE?
Old Jan 12, 2006 | 03:25 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xisda1 &raquo;</TD></TR><TR><TD CLASS="quote">THANKS FOR THE SITE I,VE ALREADY BEEN USING IT. NOW I FINISHED THE SWAP AND THERE IS NOTHING WHEN i TURN THE KEY JUST DASH LIGHTS. ANYBODY ANYBODY GOT ANY ADVICE?</TD></TR></TABLE>
YEA, TURN OFF YOUR CAPS PLEASE!!!!!!!! and search the FAQ because it will answer ALL your questions. Trust me I just did one of these swaps for the first time and I could not have done it w/o the FAQ section on this site.
If you just keep posting these too common questions you will start getting flamed.
delsoldrew
Mar 1, 2012 08:58 PM
pimpdd101
Nov 4, 2008 10:38 PM
MOVE OVER
Oct 4, 2008 06:42 AM
hatchinprogress
Dec 30, 2005 02:05 PM
JDMlyfestyle
Oct 17, 2004 05:27 PM
