More problems with my Hatchback.
Old Jan 11, 2006 | 08:40 PM
.Manny.'s Avatar
Touching My Member
Default More problems with my Hatchback.
Alright guys here it goes.
90 Hatch Si w/ Dohc ZC swap. huge Fluidyne rad and FAL fan.
#1. Temp guage doesn't work even after i plugged everything in, so im running the fan direct to the ignition. I had to because fan would not kick in even after car idled for 10 minutes. Is this bad in the long run?
#2. Needle will jump and stutter when i go WOT past 4k rpm. Motor will bog too. I have lowered suspension so when im on the highway or on the street and hit a rough spot, the CEL will flash and the motor will bog too. What can cause this??
I need a lot of help guys, the motor pulls like ish, I know it should pull alot harder because ive driven other cars wih the same swap.
Any help is greatly appreciated, I just want my car to run with no problems, this will be my daily driver as soon as i register which will prob be tommorow on thursday. Thanks!
Old Jan 11, 2006 | 08:45 PM
C1CRX's Avatar
Traffic signal tech
Default Re: More problems with my Hatchback. (90_EF_Si)
1: did u check the temp. sending sensor by the dizzy to make sure its plugged in??
2: 2 definetly* sounds ignition related is your coil good check your ignitor also
are u throwing any codes
Old Jan 11, 2006 | 08:46 PM
civic889802's Avatar
check ur wiring always double check n about the radiaor i am having the same problem it will work only when i connect the
cables to the battery
Rob.'s Avatar
1. Thermostat or wiring problem
2. Dizzy/Spark problem (running rich?)
Old Jan 11, 2006 | 10:59 PM
.Manny.'s Avatar
Touching My Member
In response to lvcrx's question, yes everything is plugged in, both plugs underneath the dizzy on the head.
In response to Rob., Im going to buy a new thermostat and have my buddy check the wiring. The dizzy works fine, i have good wires and it sends plenty of spark.
**I actually noticed that my plugs are a little browned which, from what i have read, means it is running a bit lean .
Anything else guys??? thanks again, everyone here has helped me solve every problem i've had lately.
Old Jan 11, 2006 | 11:19 PM
crxnj's Avatar
Default Re: (90_EF_Si)
1. Sounds like the ignitor
2. Maybe the fan switch is shot..Or maybe the there isnt a good connection from being dirty soaked in oil?
Old Jan 12, 2006 | 11:39 PM
.Manny.'s Avatar
Touching My Member
Ive checked everything, The car runs like **** and any moderate jolt will make it stutter and bring up the CEL. WTF? it feels like im driving a geo metro, it blows.
Old Jan 13, 2006 | 12:18 PM
.Manny.'s Avatar
Touching My Member
bump
Old Jan 21, 2006 | 11:39 PM
.Manny.'s Avatar
Touching My Member
hey guys im back and the problem is still there.
just yesterday i replaced the dizzy and it still does the same. i put fuel injector cleaner and got new spark plugs too.
later this week im going to check fuel pump and fuel components.
I was wondering if a f-ed up cat would cause this too. When i bought the car, it had a blown Dual cam zc. The guy told me that as soon as he swapped it in, the motor burned a lot of oil and smoked alot. He drove the car like that until it blew. which was like 3 months. Would three months of driving with a blown motor f up a cat and cause these problems??
one more thing, when i first put in my hmo zc, i guess i didnt tighten down the tensioner enough so the timing belt skipped maybe 2 teeth, would that be enough to bend any valves???
Thanks everyone, i appreciate this greatly because i dont have the money to take it to a shop.
Old Jan 22, 2006 | 01:10 AM
.Manny.'s Avatar
Touching My Member
ttttttt
Old Jan 22, 2006 | 09:44 AM
.Manny.'s Avatar
Touching My Member
help
Old Jan 22, 2006 | 10:33 AM
.Manny.'s Avatar
Touching My Member
cmon
petersayarath
Jun 16, 2005 04:59 PM
THugluv423
Apr 19, 2005 06:38 PM
jdmcrx1
Feb 20, 2003 09:41 AM
crxtreme27
Aug 19, 2002 01:54 PM
B16Vtec
Aug 23, 2001 09:34 AM
