Exhaust Gasket question??
Old Jan 11, 2006 | 07:54 PM
HB1234's Avatar
Default Exhaust Gasket question??
I have a blitz catback exhaust for my 00 civic hatch. The blitz system is un installed at the moment. I took off my old stock exhuast system a while back. the thing is that my blitz system didnt come with any gaskets (bought it used off a friend). I was gunna see if my stock gaskets would fit but I couldnt find them ( but i also remembered stock systems are2 piece, 2 gasket only). The blitz is a 3 piece, 3 gaskets. I need a gasket from the b-pipe to cat converter, another gasket from b-pipe to b-pipe (its a 2 piece) and a gasket from b-pipe to axle back. anyone know where I can score some gaskets? I would need a 3 bolt gasket for the converter then two 2 bolt ones for the b-pipe and axleback. would autozone or any other part store like that have them? My neighbor told me u can make your own gasket from a paste they sell at auto stores but I dunno about that.
Old Jan 11, 2006 | 08:26 PM
anony95ex's Avatar
Default Re: Exhaust Gasket question?? (HB1234)
AutoZone or Honda will be able to sell you the factory gaskets, the 3-bolt off the cat and the donut before the over-axle pipe. The third one, you're on your own. With the exception of the donut gasket that's held in with spring bolts (make sure you use spring bolts there when installing it too), the muffler sealer paste will work fine.
Old Jan 11, 2006 | 11:17 PM
HB1234's Avatar
Default Re: Exhaust Gasket question?? (anony95ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anony95ex &raquo;</TD></TR><TR><TD CLASS="quote">AutoZone or Honda will be able to sell you the factory gaskets, the 3-bolt off the cat and the donut before the over-axle pipe. The third one, you're on your own. With the exception of the donut gasket that's held in with spring bolts (make sure you use spring bolts there when installing it too), the muffler sealer paste will work fine.</TD></TR></TABLE>
the donut gasket on the axleback is only on stock mufflers. my exhaust are just flat ended. So I would need just a flat gasket. so u think that paste would work?
Old Jan 12, 2006 | 07:48 PM
HB1234's Avatar
3s1k
Jun 1, 2011 04:36 PM
tekstyle
Oct 22, 2009 06:54 PM
PINKMONST3R
Jun 15, 2004 11:45 AM
Ill
Sep 27, 2003 08:39 AM
BryanS
Sep 17, 2001 08:10 PM
