03 check engine light reset
does anybody know how to do it for this model because i tried disconnecting the battery for 10 secs and i had no luck. it reset my radio, and that's about all it did
Ok, the button inside the speedometer cluster that you use to reset the trip odometer. Push and hold it down. Turn the key to second position. Keep holding the button for 10 seconds. The light should go out. If not , read your owner's manual, it tells you how to do it somewhere.
BettyBlue21
Jul 4, 2018 08:46 AM
