Portable dvd screen want to put into car
Old Jan 11, 2006 | 06:10 PM
cfran55's Avatar
Default Portable dvd screen want to put into car
hey guys my portable dvd player is broke but the screen works i cut the red and black wires from the speakers but im so confused on how to hook it up if i can
Old Jan 11, 2006 | 07:40 PM
B18C_EJ8's Avatar
LOL.. Good luck.
That brownish "fly paper" looking stuff exiting the bottom of the circuit board is a flex circuit, which probably contains your audio and video inputs... Unless you can get ahold of the component-level schematic, you're pretty much screwed, as I can see no visible way to get another audio/video signal into that system, other than the flex that appears to be cut.
Looks like you've got yourself a nice paperweight. Depending on what was wrong with the system to begin with, you probably could have had it repaired for under a hundred bucks, but instead, you've probably caused irreparable damage.
Old Jan 12, 2006 | 08:37 AM
cfran55's Avatar
Default Re: (B18C_EJ8)
ehhhhhhhhhh i already had another portable dvd player i got this for free so i didnt really care
Old Jan 12, 2006 | 01:18 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: Portable dvd screen want to put into car (CFran55)
PLEASE LEAVE THINGS ALONE IF YOU DON'T KNOW WHAT YOU ARE DOING BEFORE ASKING THE "QUESTIONS"!
Old Jan 12, 2006 | 02:47 PM
cfran55's Avatar
Default Re: Portable dvd screen want to put into car (omega02379)
OK THANK YOU I WILL REMEMBER THAT
Old Jan 12, 2006 | 02:58 PM
MLD211's Avatar
Well if its already a paper weight you might as well try to get a signal. take a video source cut the connector off and start touching traces on that ribon cable see if you can get somthin. If its aleady junk I dont see what you could hurt. Wait can you even power the screen up? Wheres you power coming from?
Old Jan 12, 2006 | 03:03 PM
cfran55's Avatar
Default Re: (MLD211)
thanks ^^^ for a answer that can lead to something im going to try it but if not i dont mind
IntegraDriver
Audio / Security / Video
52
Sep 3, 2006 03:59 PM
Riceball
20
Aug 14, 2006 03:25 PM
Nameless
10
Apr 4, 2004 07:13 PM
WickedKP
Aug 11, 2003 09:46 PM
Aaron.
19
Mar 10, 2003 01:45 AM
