Sway Bar Help
Old Jan 11, 2006 | 02:48 PM
CiPs33's Avatar
Default Sway Bar Help
I have an 04 base rsx and i just recently installed type-r headers. Because the type-r headers are bigger than the base header, my header rubs against my front sway bar causing it to rattle. I was thinking about getting type-r sway bars. Will that work or would any aftermarket sway bar work??? Any help would be appericated, thanks!
Old Jan 11, 2006 | 07:10 PM
02ep3's Avatar
Default Re: Sway Bar Help (CiPs33)
the r bar would be your best bet b/c you know it will work...i guess any other bar could possibly work, just not as guarenteed as the legit R sway bar
Old Jan 11, 2006 | 09:20 PM
CiPs33's Avatar
Default Re: Sway Bar Help (02ep3)
so the the type-r sway bar will have enough clearance from my headers if i install it???
Old Jan 12, 2006 | 12:28 AM
Bluewind's Avatar
Don't listen to this guy, he doesn't know what he's talking about. The ITR bar will <U>NOT</U> fit your current set-up. You need the ITR front set-up which is way more money than you are most likely looking to spend. Simply put, the geometry is different. Buy either a Toda, Whiteline, or Hotchkis front sway bar or kit, depending on what you want and what each company offers.
Old Jan 12, 2006 | 02:41 PM
CiPs33's Avatar
Default Re: Sway Bar Help (Bluewind)
does any1 happen to know how much clearance is on the type-r sway bar?
Old Jan 12, 2006 | 03:15 PM
Bluewind's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiPs33 &raquo;</TD></TR><TR><TD CLASS="quote">does any1 happen to know how much clearance is on the type-r sway bar?</TD></TR></TABLE>
I have one equip'd, but I don't understand your question. It clears the race headers that are made for our cars. I don't know why you are still looking into the itr sway because I explicitly told you that it doesn't work with the stock rsx suspension layout. It's not a bolt on walk away thing. You need the itr lca's, axles, and brake assembly being the Brembos and the whole two bits. So unless you are willing to drop $1500-2000 for the sake of a sway bar, buy another brand. Like I said before, let me reiterate, Whiteline/Toda/ and Hotchkis are all brands that will bolt onto the rsx chasis and have clearance for the race header application.
Old Jan 12, 2006 | 03:35 PM
CiPs33's Avatar
thanks...ill look into it
ilvi3tkidxx
Feb 27, 2009 01:24 AM
JDMCRX
Suspension & Brakes
Jun 14, 2008 03:53 PM
energ3tic2
Northern California (Sales)
Apr 17, 2007 12:53 PM
CiPs33
Suspension & Brakes
Jan 14, 2006 07:27 AM
dc2ali
Aug 29, 2004 02:24 PM
