difference between 1997 type r motor and the 1998 and up
i am in the market for a type r motor does anyone have the jdm type motor is is worth the money for the extra 5 horsepower and 5 more ft pounds of torque.
and are emissions the same on a jdm motor
i have a ls motor with 50,000 miles on it i want to sell it and swap for a type r
cams, header, bushings (on car) %stiffer then 97 vs. 98.
ITR motor is ITR motor....for the most part. Easier to tell USDM vs. JDM cause of engine codes.
The 98 is worth it imo, cause the 96 -97 (jdm) was ported and polished by hand which had more inconsistancies in horsepower, where as in 98 they went with machine P&P and had more consitant hp #'s, plus you get the header, and the other small updates!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr »</TD></TR><TR><TD CLASS="quote">The 98 is worth it imo, cause the 96 -97 (jdm) was ported and polished by hand which had more inconsistancies in horsepower, where as in 98 they went with machine P&P and had more consitant hp #'s, plus you get the header, and the other small updates!
Not to start an arguement or anything like that at all, I'm just simply curious where you came up with that statement about the inconsistant hp numbers?
</TD></TR></TABLE>Not to start an arguement or anything like that at all, I'm just simply curious where you came up with that statement about the inconsistant hp numbers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">
Not to start an arguement or anything like that at all, I'm just simply curious where you came up with that statement about the inconsistant hp numbers?</TD></TR></TABLE>
He is right though. I have personally seen many different 96 spec ITRs making different numbers. For the most part, they are pretty consistent making between 120KW (161.9whp) to 125KW (168.25whp) with very mild mods. However, once in a while, you see 'freak' motors producing over 140KW (189whp and over) with pretty much the same mods as the other ones mentioned before.
Maybe the mechanics are more hardworking on some days?
dayaftertomorrow
Feb 21, 2006 02:31 AM
HATCHingMN
May 24, 2005 09:14 AM
