H22 H23 Prelude parts (injectors, sh cams, t-bodies, squirters, obd2-obd1 harness, calipers, etc.)
Progress adjustable rear endlinks (NEW) $80 shipped
Prothane Full bushing kit (New, but opened) to replace LCA, Endlink, & other bushings $140 shipped
Complete H22 head off of an Euro H23A with less than 25,000 miles. Comes with the vtec sensor, cams, etc. & an old valve cover I have lying around. $325 + shipping
JDM OEM H23/F20 Blue top valve cover (good shape a little of the paint got scraped off on the edge near the dizzy)- $100
Type SH cams- $80
H22 Intake Manifold- mildly ported, but heavily modified, the EGR system is completely removed then welded over, with unused NOS Wet nozzles in place - $100
Crower H22 Rod, just one the good quality rod $70
5th gen rear ABS sensors- $15
4th gen calipers (from an 'S')- $30 for front pair, $10 driver's side rear
4th gen front driver's side LCA $10
4th gen Cruise Control- $25
Aluminum AC bracket- $45
Iron AC bracket- $10
H22 Thermostat Housing- $30
Alternator (obd2)- $40
AC Compressor (obd2)
Distributor H22 internal coil obd1- $75
OEM Fuel rails- $5
Oem Cam Gears- $10
VSS- 5th Gen- $60
VSS- 4th gen- $60
I also have several parts harnesses, engine bay & chasis, so if you need any odd plugs, chances are I have it.
SOLD ITEMS
Euro R Manifold
Type S/Euro R 62mm Throttle-Body with an intact TPS (plate is 62.5mm)
Euro R/H23a injectors
Euro R/H23a Fuel rail (may help those of you with Euro R Mani's)
Euro R/H23a IAC & plug
Obd2-obd1 conversion harness
Stock H23 Intake Manifold, lower half
AEM Underdrive Alternator Pulley
Dizzy H22 obd1 external coil
H22 obd1 345cc injectors
IAB actuator black box thing
Starter
Oil Squirters
H22 Throttle bodies
Driveshaft Shop Stage (dss) stage 2 axles
Custom 4th Prelude car cover
Pics:
Modified by 2lude4u at 7:06 PM 3/1/2006
Type SH cams- $80
OEM Fuel rails- $5
Oem Cam Gears- $10
VSS- 5th Gen- $60
VSS- 4th gen- $60
SOLD ITEMS
Euro R Manifold
Starter
Oil Squirters
H22 Throttle bodies
Pics:
Both are in working order. The obd1 is set up as external coil (can not be converted back to internal) so you need to be running an MSD or OEM external coil set up.
pm'd
pm'd
