Extreme Shifting???
Old Jan 11, 2006 | 02:00 PM
SDT Project EF's Avatar
Default Extreme Shifting???
Hey guys, Almost done with a GSR swap in an EG hatch. Only problem is when i hook up the shift linkage the shifter slams into the plastic center console. Do i have the right linkage? If i flip flop the shifter either way it either hits the front of the center console, or it hits the back of the center console. The shiftlinkage is kinda of a gold color too if that helps determine what car it came from. Any help is greatly appreciated. Thanks honda-tech
Old Jan 11, 2006 | 02:12 PM
Chin0280's Avatar
Default Re: Extreme Shifting??? (SDT Project EF)
bump for you because i never had this problem with a gsr swap, it did get close to hittin the console but it was fine for me
the reid's Avatar
Can you say for sure which linkage you have? any b series teg 94-01 should work fine, baring its not damaged. This is of course is except for the del sol vtec linkage and the DA teg linkage (90-93).
Old Jan 11, 2006 | 02:16 PM
Default Re: Extreme Shifting??? (the reid)
I bought a complete swap i was told the linkage was from a GSR.
Old Jan 11, 2006 | 02:26 PM
the reid's Avatar
well without pics to compare its hard to tell ya anything else helpful, if its a 94+ teg, it should work alright, i no the da teg linkages are about 1 inch shorter, so if you can confidantly say that you trust the seller, and you recieved the gsr linkage, i can only assume it is damaged? perhaps the misinformed attempted to straighten it?
also the ek sir linkages are different as well and will not work properly. i would most logically surmise that the seller got just any old b series linkage assuming it would work.
at any rate, replacement are not that much money, if you problem continues i would sugest just getting a new linkage, avid or oem, both are only like 150 new, or find a used set on here.
Old Jan 11, 2006 | 03:08 PM
Thanks for the advice. bump before I go to work
Old Jan 11, 2006 | 08:38 PM
Orangedragone's Avatar
switching in/out a dual bend shifter help? just tossing an idea.
deaton333
Jan 15, 2008 03:54 PM
Vtakkk
May 15, 2006 03:58 PM
jdmintegra1994
Nov 25, 2003 06:22 PM
SpdFrk
Jun 25, 2003 08:16 AM
