question about S2000 parts into eg hatch.... Help please
Old Jan 11, 2006 | 01:40 PM
J1A1H's Avatar
Default question about S2000 parts into eg hatch.... Help please
A friend of mine is breaking his S2000.
I am taking his seats and his steering wheel if that will fit?
Also i am wondering how easy it is to drop an s2000 engine into an eg? and whats the model of it?
Also is it possible to put the brakes (calipers,disks,and pads) into an eg?
Also is there anything i can take of this s2000 while i can?
THANKS A LOT!!!
Josh
Old Jan 11, 2006 | 01:49 PM
92BluEH-3's Avatar
lulz
Default Re: question about S2000 parts into eg hatch.... Help please (J1A1H)
the seats will go in there is a write up if you searched and the motor "will" fit if you have the money. incase you dont know im not sure but s2k's are rwd and you drive a fwd........... there will be a lot of work involved and im not sure about the brakes and the steering wheel
Old Jan 11, 2006 | 01:59 PM
J1A1H's Avatar
yea..
I know the seats will fit, and i know the engine will... i did a search but there wasnt too much about the engine into an eg.
I am just wondering if there is anything else i could take from it.
Old Jan 11, 2006 | 02:14 PM
NineTwoSi's Avatar
Good luck with fitting the motor in... It takes considerable fabrication and converting your car to RWD. For a 240hp engine you might as well just buy an H22A at half of the cost of the F20C and boost that bitch... Make much more power and won't go broke trying to make it fit.
Old Jan 11, 2006 | 02:36 PM
J1A1H's Avatar
hmmm... so basically your saying its not really worth all the effort?
ill say again... is there anything else i cant take off the s2000? BRAKES? steering wheel?
Old Jan 11, 2006 | 02:47 PM
NineTwoSi's Avatar
Default Re: (J1A1H)
Yes... Even if you got the S2000 engine for free it would cost far more in fabrication just to fit the motor in than an H22 would cost for the motor plus installing it... and it only has 40hp less than the F20 stock which you could easily gain with bolt-on's and or boost. The seats are pimp though!
Old Jan 11, 2006 | 02:50 PM
x_outlaw_x's Avatar
the seats are really the only thing worth taking...unless you wanted to do an s2000 dash conversion which ive never seen...you should try it...steering wheel shouldnt fit, brakes wont, suspension wont, engine isnt worth the effort time or money, you could get some itr suspension and put the s2k rims on
Old Jan 11, 2006 | 02:54 PM
NineTwoSi's Avatar
Default Re: (J1A1H)
Here's a DIY link for S2000 seats in a civic.
https://honda-tech.com/zerothread?id=347548
TRYLSTEG808
Aug 2, 2007 04:06 PM
92eg6lsvtec
Aug 28, 2006 01:12 AM
HondaS2000
Honda S2000
31
Jul 21, 2006 05:47 AM
HondaS2000
Jun 19, 2006 09:07 AM
mugencivic94
Nov 8, 2005 09:02 AM
