150,000 Miles 93 Accord LX: maintenance questions
Old Jan 11, 2006 | 11:05 AM
spartan6's Avatar
Default 150,000 Miles 93 Accord LX: maintenance questions
Ok I got this car from my parents in June 05.
I know i got an oil leak from the valve cover,
also the belts need to be replaced, trani oil replaced, and the radiator flushed.
How hard is it to replace the valve cover gasket, change the trani fluid, flush the radiator, and most importantly the belts?
I realize these are fairly routine things, but the dealer wants $369.00 to do the general 150,000 mi check-up (which is insanity since the T-belt is fine) most of the stuff they do is easy and I know how, but I need some advice on these specifics.
any help would be greatly appreciated!!!
Old Jan 11, 2006 | 11:12 AM
DrYeRLiNt27's Avatar
Default Re: 150,000 Miles 93 Accord LX: maintenance questions (spartan6)
belts are easy... on the alternator and a/c compressor there is an adjustment to raise/lower them you lower them, replace belts, and raise them. easily a 15 min job on a non-wrecked car (or on mine its a 90 min job due to that side being smaller than it should be!)
Old Jan 11, 2006 | 11:14 AM
spartan6's Avatar
Default Re: 150,000 Miles 93 Accord LX: maintenance questions (DrYeRLiNt27)
Thanks for quick reply.
now is it easier to have the car jacked up or can I have it normal?
Old Jan 11, 2006 | 11:56 AM
92ehatch's Avatar
valve cover gasket is easy. buy a new gasket kit from advance for like 16 bucks, replace all the gaskets.
there are 4 acorn nuts to remove and the ground fromthe valve cover to the chasis.
replace all seals/gaskets and apply hondabond or RTV blue silicone to the corners of the valve cover gasket. trq the nuts in a criss-cross pattern to 7lb ft.
run the car for a couple days and retorque (because as the seals seat they will need to be retorqued a bit)
Old Jan 12, 2006 | 08:56 AM
spartan6's Avatar
Default Re: 150,000 Miles 93 Accord LX: maintenance questions (93cb7sedan)
Can I get Hondabond or RTV blue silicone anywhere? and how careful do I need to be with the ground? someone else told me about the ground but not in very good detail.
appreciate the reply!!!
Old Jan 12, 2006 | 10:04 AM
Honda-Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spartan6 &raquo;</TD></TR><TR><TD CLASS="quote">Can I get Hondabond or RTV blue silicone anywhere? and how careful do I need to be with the ground? someone else told me about the ground but not in very good detail.
appreciate the reply!!! </TD></TR></TABLE>
you can get hondabond from the dealer ,, but instead get the ( ultra flange sealant) it is cheaper and as good ,, dealer sells it as well..
NAcb7
May 13, 2009 10:39 PM
dafox99
Jul 16, 2008 03:36 PM
carneth
Aug 2, 2004 12:25 PM
DM
Mar 29, 2004 06:01 PM
Rev-Olution
Oct 4, 2003 10:17 PM
