(sos) can ne body help with 93 2.2 vtec si engine diagram need to replace oilseals
Hi can ne1 help with a engine diagram my baby has a serious oil leak in top end or crankshaft cant really c, too much oil all over need diagram so as to c how many oil seals and replace the lot,would be much appreciated
http://www.hondaautomotiveparts.com and http://www.slhondaparts.com both have complete diagrams of every part on your car. Just search around in the engine catagories.
hiya doing mate jeff from uk here ,thanks for the reply,those links are for spare parts i need to c a diagram of the motor so as to see how many and where the oils seals are, cheers
I know what those links are for, and if you look at the diagrams you'll find all the oil seals. I don't know of one diagram that only shows all of the oil seals....
i dont know why you cant find them all on that site, but here is a list if you want to replace every single one, from the top down:
valve cover stud grommets
valve cover gasket
front and rear cam seal
cam plug
vtec solenoid seal
distributor shaft seal
headgasket(technically seals oil)
oil cooler gasket
front balance shaft seal
front main seal
rear main seal
oil pan gasket
valve cover gasket
cam plug
vtec solenoid seal
oil cooler gasket
front main seal
rear main seal
oil pan gasket
knoj
Aug 24, 2005 06:51 AM
SPOON_BeIgHtEeNsEe
Oct 26, 2001 05:29 AM
