what are the size of the stock motor mounts bolts for a 89 crx si
Old Jan 11, 2006 | 09:44 AM
h22_crx's Avatar
Default what are the size of the stock motor mounts bolts for a 89 crx si
Old Jan 11, 2006 | 11:29 AM
h22_crx's Avatar
Default Re: what are the size of the stock motor mounts bolts for a 89 crx si (h22_crx)
help
Old Jan 11, 2006 | 12:29 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I'll help you man..
>>>12mm X 1.5mm X 100mm
[Drivers side and transmission mount]
The rear mount used a longer bolt with a spacer
>>>125mm with 25mm spacer but the shorter bolt
mentioned above would work..
p.s. the front bolt is about 100mm long
with a special nut..The lengths given are the total length
including the head..
Old Jan 11, 2006 | 04:11 PM
h22_crx's Avatar
Default Re: what are the size of the stock motor mounts bolts for a 89 crx si (88DXCRX)
thats a start
Old Jan 11, 2006 | 04:21 PM
Tyson's Avatar
bolt sizes are listed in the parts description.
http://www.slhondaparts.com/br...MOUNT
Old Jan 11, 2006 | 05:14 PM
h22_crx's Avatar
Default Re: what are the size of the stock motor mounts bolts for a 89 crx si (Tyson)
thanks
Old Jan 11, 2006 | 05:18 PM
Tyson's Avatar
im curious, are you planning on using non OEM bolts?
i wouldnt if you are thinking about it.
Old Jan 11, 2006 | 09:41 PM
h22_crx's Avatar
i am puting a zc back in my crx and i cant find some of the bolts
Old Jan 11, 2006 | 11:27 PM
Tyson's Avatar
find the bolts at the junkyard. or just buy new. dont use anytihng from the hardware store for this.
azhfreak
Aug 27, 2018 11:21 AM
GroundZer0 336
Jun 27, 2009 06:01 AM
South Bay Surfer
Jul 21, 2005 03:32 PM
d_mina
Sep 15, 2004 02:47 PM
DA-MAX
Nov 23, 2003 05:15 PM
