Will an alignment be needed after replacement of the drive axles?
Old Jan 11, 2006 | 06:32 AM
diyer's Avatar
* B A N N E D *
Default Will an alignment be needed after replacement of the drive axles?
1994 Accord Ex, 4 door, 160K
F22B1 V-Tec Engine, CD5 Chassis
My Helms manual says to check the alignment after replacing the drive axles. But most people I have asked this question have said no, as long as, I do not mess with the tie rod. Did Honda have this put in the manual as a possibility or is it a given that follows?
Is it a clear yes or no answer?
Old Jan 11, 2006 | 06:41 AM
P_Adams's Avatar
Default Re: Will an alignment be needed after replacement of the drive axles? (diyer)
No, it will <U>NOT</U> be necessary.
The "chk the alignment" is like a "cover your a...s" thing. If you don't disturb things, it will go back the same way it came apart
P
brownie75
Transmission & Drivetrain
May 27, 2015 02:00 PM
Terabass
Jan 10, 2008 02:08 PM
classciv
Dec 6, 2005 11:50 AM
