Anyone with a hood lock install how to?
Old Jan 11, 2006 | 05:32 AM
monicle's Avatar
Default Anyone with a hood lock install how to?
Ive got some hood locks to install but Im wondering if someone can post up some pictures of where they mounted them? I would REALLY prefer to drill my hood in the right spot so a little help would be appreciated.
btw hood pin install pictures are not going to help me in any way.
Old Jan 11, 2006 | 05:56 AM
AutoXer's Avatar
Default Re: Anyone with a hood lock install how to? (monicle)
I'm guessing this isn't a cable type lock? Could you post a link to the product that you have?
Old Jan 11, 2006 | 06:13 AM
monicle's Avatar
Default Re: Anyone with a hood lock install how to? (AutoXer)
Old Jan 11, 2006 | 06:38 AM
litterbox's Avatar
I am a (Trial User) Army
Where'd you get that?
Old Jan 11, 2006 | 07:02 AM
monicle's Avatar
Default Re: Anyone with a hood lock install how to? (litterbox)
summitracing.com
Old Jan 11, 2006 | 07:07 AM
nekoabandoned's Avatar
i want 1(if it was invisable), but for the install its just like doing hood pins. drill the holes for the locks and if there arnt already there, drill holes for the rodes to mount on the frame. the only diff between hood pins and ur locks is that the rode doesnt go through the hood, so after u get the locks in and the rodes in just adjust the rode to where it meets the locks under the hood. make sense?
Old Jan 11, 2006 | 07:11 AM
litterbox's Avatar
Default Re: Anyone with a hood lock install how to? (nekoabandoned)
So that circular thing is on the outside of the hood? That's retarded.
Build a bracket that goes behind your front bumper and padlock it.
Old Jan 11, 2006 | 07:18 AM
lol i thought u didnt know how to mount them sorry mount them in the same place as u would hood pins
Old Jan 11, 2006 | 07:22 AM
monicle's Avatar
no these locks dont allow the room for sloppiness that hood pins do. as you can see the black pin on the lock cylinder has to line up with the slot on the bolt looking part in order to lock it down.
Im well aware that holes need to be drilled but im looking to see where someone with these style of locks has done it so that i can be sure that they will line up right.
Old Jan 11, 2006 | 07:23 AM
ill look for some pics for u
Old Jan 11, 2006 | 07:25 AM
monicle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">So that circular thing is on the outside of the hood? That's retarded.
Build a bracket that goes behind your front bumper and padlock it.</TD></TR></TABLE>
yeah because padlocks are sooooo much harder to defeat than a tubular cylinder lock.
As for the plate being on the outside of the hood.... sometimes security is more important than looks. I could give 2 ***** about what they look like. Im more interested in what they are actually doing.
Modified by monicle at 10:00 AM 1/11/2006
Old Jan 11, 2006 | 07:43 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">Im more interested in what they are actually doing.</TD></TR></TABLE>
Well of course. I don't like this design becuase it's just exposed. Couldn't you just drill that? What's it made out of?
With a hidden padlock placed in that tiny amount of space, a theif wouldn't be able to fit a cutter or saw in there to destroy the padlock or bracket.
Old Jan 11, 2006 | 07:54 AM
monicle's Avatar
With a hidden padlock placed in that tiny amount of space, a theif wouldn't be able to fit a cutter or saw in there to destroy the padlock or bracket.</TD></TR></TABLE>
Those locks are fairly time consuming to drill out since the pins are arranged around the lock rather than in a straight line through the center like a standard lock
If i can fit my hands in there to take a padlock off of a bracket I can fit bolt cutters in there and cut it for sure.
Old Jan 11, 2006 | 07:56 AM
litterbox's Avatar
That's cool. As long as it's not drillable.
You can't get to the padlock or bracket by just reaching through the front bumper grill. You have to go underneath and really curve your hand in a weird way. There's no way you can cut my bracket. Seriously.
Old Jan 11, 2006 | 10:10 AM
monicle's Avatar
bump for pics
Old Jan 11, 2006 | 10:30 AM
x_outlaw_x's Avatar
when i did these on my friends car there were 2 holes on the radiator support that were perfect for the rods...we just put some grease on the end of the rod after we put it through the hole then set the hood down on it and thats where we drilled the holes
Old Jan 11, 2006 | 11:31 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">You can't get to the padlock or bracket by just reaching through the front bumper grill. You have to go underneath and really curve your hand in a weird way. There's no way you can cut my bracket. Seriously.</TD></TR></TABLE>
Exactly... my friends is just like that.
Old Jan 11, 2006 | 11:37 AM
litterbox's Avatar
Default Re: Anyone with a hood lock install how to? (Tippyman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman98 &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly... my friends is just like that.</TD></TR></TABLE>
Finally.
Old Jan 11, 2006 | 11:56 AM
pdiggitydogg's Avatar
hope youre not using those for a carbon fiber hood, in place of pins....
http://www.hstuners.com/forums...22931
This is for hood pins, but you can still follow it along for the most part (just make a larger hole for the big locks to slide in through)
Old Jan 11, 2006 | 12:13 PM
monicle's Avatar
Default Re: (pdiggitydogg)
nope stock hood.
Old Jan 11, 2006 | 01:07 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (monicle)
These are my hood pins/locks. Saw them on the 800+whp / 200+mph EVO8 and I had to have them.
I had much better pics from a photoshoot, but I can't seem to find them. Be prepared for a more time-consuming install, and to pay almost $100 for a set of two.
Anyway, they're from http://www.aerocatch.com
sometimes security is more important than looks. </TD></TR></TABLE>
Safety &gt; Security &gt; Appearance
Old Jan 11, 2006 | 01:52 PM
Suzukablue's Avatar
i have the NRG hood locks just like yours. i had it installed at robear and man it took hours and hours for them to install it. but in the end it was perfect. my $40 was worth it. goodluck on yours
Old Jan 11, 2006 | 03:35 PM
undertheradar's Avatar
Default Re: (Screwtape.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screwtape. &raquo;</TD></TR><TR><TD CLASS="quote">These are my hood pins/locks. Saw them on the 800+whp / 200+mph EVO8 and I had to have them.
Safety &gt; Security &gt; Appearance</TD></TR></TABLE>
Those are pure sex!
Old Jan 11, 2006 | 03:41 PM
5lugSlug's Avatar
i thought u just put them in the metal peice right above the headlights (drill holes)?
Old Jan 11, 2006 | 07:01 PM
monicle's Avatar
Default Re: (EK-tacy98)
well i guess ill just have to give it a try since noone can put a picture up.
