What type of nasty fluid did Honda put in this thing?
Old Jan 11, 2006 | 02:37 AM
Draggin99Si's Avatar
Default What type of nasty fluid did Honda put in this thing?
I have a busted driver side motor mount which splattered the fluid inside it all over the engine bay. Whatever it touched, it permanently stained it. The oily substance eats into whatever it comes in contact with. It will not come off even with Simple Green and scrub pads.
Exactly what type of fluid is this?
Modified by Draggin99Si at 4:17 AM 1/11/2006
Old Jan 11, 2006 | 03:31 AM
Tippyman's Avatar
Gross, it won't come off at all?
Old Jan 11, 2006 | 03:38 AM
Default Re: (Tippyman98)
Nope, won't come off at all. The underside of my hood also got splattered with this junk. It is like permanent marker....... once it's on, it's on there forever.
Old Jan 11, 2006 | 03:41 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (Draggin99Si)
Try break cleaner?
Old Jan 11, 2006 | 04:03 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Try break cleaner?</TD></TR></TABLE>
Brake cleaner works wonders.... did you fix the broken mount?
Litterbox, what happen to your posts? And your avatar?
Old Jan 11, 2006 | 04:16 AM
litterbox's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Litterbox, what happen to your posts? And your avatar?</TD></TR></TABLE>
I temporarily stored them in your moms box.
They'll be back soon.
Old Jan 11, 2006 | 04:19 AM
elise's Avatar
hmm.. that doesnt happen too often.....
Old Jan 11, 2006 | 04:26 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
They'll be back soon.</TD></TR></TABLE>
Whatever you say.
/end threadjack
Old Jan 11, 2006 | 04:37 AM
The rubber part ruptured which caused the fluid to splatter. I thought it was composed of solid rubber. I never knew it was liquid filled. I'll be replacing the whole mount soon.
Old Jan 11, 2006 | 04:58 AM
nsxmatt's Avatar
The mount is filled with anti-freeze/water. It's a fluid filled mount and when they bust the fluid which has rusted over time, will splatter all over. Good luck getting it off, the underside of the hood and engine bay is not clear coated and the paint will come off with any real harsh chemical.
Old Jan 11, 2006 | 05:03 AM
ruthless013's Avatar
Default Re: (nsxmatt)
welcome to the club - driving around with a stained white hood since 2001.
Old Jan 11, 2006 | 06:47 AM
Buzzbomb's Avatar
Default Re: What type of nasty fluid did Honda put in this thing? (Draggin99Si)
Gross, that's a nice little tidbit of info to know.
*note to self to keep an eye on motor mounts
Old Jan 11, 2006 | 08:09 AM
MadSuRfEr's Avatar
it wont come off!!!!!!!!!!!! been there.
Old Jan 11, 2006 | 08:21 AM
khmboostedeh2's Avatar
Default Re: (ruthless013)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruthless013 &raquo;</TD></TR><TR><TD CLASS="quote">welcome to the club - driving around with a stained white hood since 2003.</TD></TR></TABLE>
2004 here..
Old Jan 11, 2006 | 08:31 AM
Jay_Sensing's Avatar
First time I broke one, I thought I had blown a HG, looking everywhere for the leak smelling the antifreeze and seeing the splatter but the exhaust was good and no smoke lol. Took me like 30 minutes to figure out what happened, stressed the hell out of me.
Old Jan 11, 2006 | 01:33 PM
pumpkyn's Avatar
i'm going to go check my mounts now
Old Jan 11, 2006 | 02:31 PM
LShatchie's Avatar
Default Re: (pumpkyn)
what car does this mount come in? i know my moms crv has it but thats all
Old Jan 11, 2006 | 03:18 PM
Mugen112's Avatar
hmm... not trying to thread jack or anything, but i does anyone know why honda would put anti-freeze/water in a motor mount??
Old Jan 11, 2006 | 03:32 PM
So it will still absorb vibration when it's below freezing out.
Old Jan 11, 2006 | 03:40 PM
Rev2Eight's Avatar
Default Re: (Jay_Sensing)
so what are some of the early signs of this? There a mileage interval? Wanna keep the engine bay fresh and clean clean
Old Jan 11, 2006 | 09:42 PM
Default Re: (Rev2Eight_EM1)
mine went when i had a b16 swapped in my 96 coupe - i believe they use the same driver's side mount. must have been all that extra torque.
since replaced with a hasport replacement mount.
Old Jan 11, 2006 | 10:33 PM
dohcVTECeg2's Avatar
^^^hasport adds a nice touch
Old Jan 11, 2006 | 10:42 PM
eXcelonTypeR's Avatar
Default Re: (dohcVTECeg2)
It's almost worth the extra cash to replace em with Hasport ot the like, regardless if you swapped or not....I feel for you thou
Old Jan 11, 2006 | 11:05 PM
Default Re: (eXcelonTypeR)
How much is the Hasport mount?
Old Jan 12, 2006 | 12:18 AM
Redline96LX's Avatar
* B A N N E D *
I'm gonna go spray some clear coat on the underside of my hood.
