FS: H22 ALL MOTOR Crower Maxi-lite rods and 90mm Endyn Rollerwave pistons
I am selling a set of brand new in box, never been used Crower Maxi-lite rods and 90mm Endyn Rollerwave pistons. These are the Endyn high compression ones, the compression ahould be about 12.5:1 depending on flat faced valves and how much the head is milled. The pistons also come with rings. The Crower Maxi-lite rods are perfect for all motor setups because they are significantly lighter than stock and most aftermarket rods such as Eagles.
The price on these is $1300.
only if i already had a sleeved h22 block...you wouldn't happen to have other h22 all motor parts would you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmintegraxsi »</TD></TR><TR><TD CLASS="quote">just have your block bored out a little bit to 90mm. You know you want these
boring it 3mm on stock sleeves will be a little too crazy...also, i dont think those pistons will mate too well with frm sleeves...anyways, good luck with your sale.
</TD></TR></TABLE>boring it 3mm on stock sleeves will be a little too crazy...also, i dont think those pistons will mate too well with frm sleeves...anyways, good luck with your sale.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECJUN »</TD></TR><TR><TD CLASS="quote">Do you still have this most awesomly amazing deal available?</TD></TR></TABLE>
Sure do. Just sittin here waiting to be run. Come on someone needs rods and pistons. They don't even sell the 90mm bore anymore.
jdmintegraxsi
Mar 25, 2006 08:54 PM
jdmintegraxsi
Feb 14, 2006 01:26 PM
wespirl
Dec 3, 2003 03:02 AM
