Any Benefits: Installing an Integra Purge Solenoid w/ my ls swap
Old Jan 10, 2006 | 08:06 PM
Nisif's Avatar
Default Any Benefits: Installing an Integra Purge Solenoid w/ my ls swap
I'm wrapping up small details with my ls swap into my 91 Civic dx. Tonight I routed my vacuum lines correctly. However, after looking at numerous vacuum diagrams of different models, Is there any benefit to adding the additional (think it's called) purge solenoid which comes factory on the DA integra chassis. This is located right next to the map sensor on the integra, I noticed my 91 Civic dx doesn't have one, however my DA does. Btw, I'm running a pr4 ecu in my Civic, I was wondering if the ecu might be searching for this additional emissions control. If any of you are running this with your ls swap let me know if you've noticed a difference or not.
Old Jan 10, 2006 | 08:49 PM
dravesef's Avatar
doing the same swap and was wondering the same thing. anyone have any input
Old Jan 11, 2006 | 12:47 AM
Rywire's Avatar
Default Re: (dravesef)
You can run any purge solenoid. Just use the stock ef one if you want.
Old Jan 11, 2006 | 02:34 AM
jisu009's Avatar
Default Re: (droppedcrxsi)
I just got rid of mine.
Old Jan 11, 2006 | 06:24 AM
jlicrx's Avatar
Default Re: Any Benefits: Installing an Integra Purge Solenoid w/ my ls swap (Nisif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nisif &raquo;</TD></TR><TR><TD CLASS="quote"> Is there any benefit to adding the additional (think it's called) purge solenoid which comes factory on the DA integra chassis. This is located right next to the map sensor on the integra, I noticed my 91 Civic dx doesn't have one, however my DA does. </TD></TR></TABLE>
your DX should have had a Purge Control Solenoid Valve along with the MAP - what it didn't have, that the DA does, is the Fuel Pressure Regulator Control Solenoid Valve - do you need it? Honda must have thought so since they put it there
Old Jan 11, 2006 | 07:54 AM
wickedEFguy's Avatar
Default Re: Any Benefits: Installing an Integra Purge Solenoid w/ my ls swap (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">
I would like to know this as well. My FPR is hooked directly to my intake manifold since I have 2nd GEN B16 intake manifold. should I re-route the lines to the Fuel Pressure Regulator Control Solenoid Valve?
Old Jan 11, 2006 | 05:36 PM
Nisif's Avatar
your DX should have had a Purge Control Solenoid Valve along with the MAP - what it didn't have, that the DA does, is the Fuel Pressure Regulator Control Solenoid Valve - do you need it? Honda must have thought so since they put it there</TD></TR></TABLE>
Good info...Is there a wire that runs from the ecu to the Fuel Pressure Regulator Control Solenoid Valve? If so, would you happen to know the pinout? I might try running this and see if it makes a difference in fuel consumption or not, if I can get the pinout from the ecu. Anyone out there that has already done this? I figured maybe some of you in Cali might due to strict emission tests...really not sure if it's required or not for testing.
Old Jan 12, 2006 | 08:25 PM
Nisif's Avatar
Up, somebody is running this w/ their swap
ELSUICIDA
16
Nov 22, 2006 05:09 PM
pkgwjai082
Northeast (Sales)
Jan 16, 2006 12:02 AM
Hybrid CRX
18
Oct 9, 2002 06:12 PM
