Replacing lower balljoin on 02 RSX Type S
I pwn3d a lower balljoint and had to replace it. I ordered it from NAPA and it came to like 65$ and some change. When I removed the old balljoint from the spindle I didn't notice any lock ring. When I got the new one, it had a lock ring. Is it mandatory that the lock ring is used?
Please, I really don't care for your opinions, I only want replies with expirenced situations.
I think im the only one that owns a DC5 that works on there own car.
Theres a steel circular ring thats not a complete circle. Your suppose to clip it on the bottom of the ball joint to lock it in place. Hence the name. Lock ring. Type S OEM ball joints dont come with lock rings, there just pressed in.
bah, I have another question.
I was removing the axels and it seems the passenger axel which is connected to the half shaft didn't want to come out. Is there a pin holding the passenger axel into the half shaft that im not seeing? I tried tugging on the axel carefully , making sure not to seperate the axel and all that happend was it was pulling the axel and the half shaft. I looked and couldn't find a pin or ring anywhere holding it in.. Any help?
have you pulled out Honda axles before? there very tight. People ive talked to have had to use a crowbar or two, and a friend helps.
Regarding the balljoint, I dont have the RSX helms book on me, but for 65$ it seems you coulda gotten a OEM one from a dealer. Off the top of my head, I don't think there is a snap ring on top.
Napa isnt 100% on their parts, sometimes they include certain pieces to make lists of **** complete, if ya get my drift. Like if you buy a certain drain plug bolt, you cant get it without also getting the washer with it.
jermo
14
May 10, 2019 03:07 PM
MainStreamHonda
10
Oct 7, 2014 08:40 PM
Lance C
18
May 7, 2004 09:12 PM
