aem cold air intake interchangable between H23 and H22?
Old Jan 10, 2006 | 02:32 PM
ralpheezy's Avatar
Default aem cold air intake interchangable between H23 and H22?
I just recently found that my crankcase was leaking oil instead of my oil pan which I thought the oil was coming from the whole time. I decided that this is a good enough reason for me to swap to an H22 and forget the turbo H23 project for a while until I finish college since I need this car to drive back and forth.
I have a few questions regarding the intake:
1. Are the throttle bodies on the H22 and H23 the same size?
2. Do the AEM CAIs for both engines have the same inside diameter?
3. Will it matter if I use my H23 CAI on my new H22?
A simple yes or no would be good enough. Thanks.
Old Jan 10, 2006 | 02:58 PM
AndyD's Avatar
Default Re: aem cold air intake interchangable between H23 and H22? (ralpheyizzle)
They are the same.
If I were you, I would get a 5th Gen AEM intake. It's of a slightly larger diameter than the 4th Gen's.
I had a 5th gen when I had my H23, I have one now that I have an H22.
Old Jan 10, 2006 | 03:33 PM
BlueLude94's Avatar
Default Re: aem cold air intake interchangable between H23 and H22? (AndyD)
I am using the same intake from my H23 on my H22, So yes, but it is not AEM
Old Jan 11, 2006 | 03:38 PM
ralpheezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">They are the same.
I had a 5th gen when I had my H23, I have one now that I have an H22.</TD></TR></TABLE>
That's cool. AEM intakes are cheap these days. When I got mine when I was 15, they cost more than $400. Now you get them for only $50. Hahaha.
asmallsol
Aug 23, 2006 03:58 AM
yanin_flo
Jun 6, 2006 07:55 PM
SAVIOVEGA
Jul 31, 2004 04:36 PM
96SR-V
Mar 11, 2004 03:58 PM
accorracer
Dec 30, 2002 10:15 PM
