OBD Connector not reading
Old Jan 10, 2006 | 02:26 PM
dungsta's Avatar
Default OBD Connector not reading
i need a smog for my itr .. got the car for 2 years already.. went to a smog shop connected the obd connector and the rpm signal wont read.. i need help!!... anyone out there know why my obd connector isnt reading?
Old Jan 11, 2006 | 11:27 PM
dungsta's Avatar
Default Re: OBD Connector not reading (dungsta)
i got a jdm motor to add .. just wondering if jdm motors are obd1 or obd2 ...
anyone?
Old Jan 15, 2006 | 01:22 AM
96dc2's Avatar
What year is your ITR? What year is your motor? Any modifications to the engine harness? Any mods to the ECU?
Old Jan 15, 2006 | 09:29 AM
92TypeR's Avatar
FSAE
Default Re: OBD Connector not reading (96dc2)
The OBD service connector will only work with the same OBD ECU. IE: A '97 ITR OBD connector will only work with a OBD2a ECU.
I am not positive if the service connector will work with a JDM ECU either.
Old Jan 15, 2006 | 12:15 PM
98 Spec R's Avatar
Default Re: OBD Connector not reading (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I am not positive if the service connector will work with a JDM ECU either.</TD></TR></TABLE>
The JDM ECU's do not have the OBDII service connector plug electronics in them. You must run a USDM ECU for the OBDII service connector to work. Also, if you have a JDM motor you will not be able to run the USDM ECU without adding a VTEC Oil pressure switch on your VTEC Solenoid and a CKF sensor on your oil pump. The JDM ITR motors do not come with these sensors.
Apex i ITR
Jun 13, 2011 06:12 PM
Jap_Spec_Imports
Jun 2, 2009 06:12 PM
ctr status
Sep 14, 2006 05:10 PM
project_mercy
Dec 20, 2002 09:37 AM
808State
Oct 9, 2001 05:47 AM
