ECU HELP!!!!
Old Jan 10, 2006 | 10:49 AM
Fusion G2 Civic's Avatar
Default ECU HELP!!!!
Switching over to MPFI and have a 89 Si Prelude ECU... is it compatabe? because the motor will crank but not turn over
Old Jan 10, 2006 | 10:55 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: ECU HELP!!!! (Fusion G2 Civic)
do you have an 89 prelude engine in your car? you might want to look for an ecu that is for the engine you have, or atleast an ecu that has been chipped for your engine. im not even sure the preludes have the same pin out as some of the smaller displacement obd0 ecus.
Old Jan 10, 2006 | 10:57 AM
Default Re: ECU HELP!!!! (sanimalp)
I have the d15b1 but i was told to get an Si ECU... is the Si prelude obd0?
Old Jan 10, 2006 | 11:09 AM
jlicrx's Avatar
the 89 Prelude Si distributor will not work with your MPFI - it doesn't have a Cylinder Position Sensor in the distributor - on the Prelude Si, it is on the end of the exhaust camshaft, like a DOHC ZC or Integra D16A1
whoops! sorry - thought you were asking about distributor
Old Jan 10, 2006 | 11:18 AM
Default Re: ECU HELP!!!! (jlicrx)
IM NOT TALKING ABOUT THE DIZZY IM TALKING ABOUT THE ECU AND IF IT CAN WORK OR NOT
Old Jan 10, 2006 | 12:03 PM
my bad on the caps
Old Jan 10, 2006 | 12:33 PM
Mach69's Avatar
It wont work. What is meant by when you need an 'Si' ecu, it means a crx or civic si from 88-91, not a prelude si. Basically you need a pm6 ecu.
Old Jan 10, 2006 | 07:49 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: ECU HELP!!!! (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">It wont work. What is meant by when you need an 'Si' ecu, it means a crx or civic si from 88-91, not a prelude si. Basically you need a pm6 ecu.</TD></TR></TABLE>
yes.
jarhead90crx
Jun 29, 2011 04:15 AM
Kchambers
Jul 18, 2009 08:16 AM
