Will an ITR exhaust fit an ek?
No, the exhaust lengths are not correct. The b-pipe isn't far off and would require extending depending on which motor you've got in there (B-series or D-series most likely). The axle-back also would need to be hacked up to make it work. You're better off going with a custom exhaust and welding an ITR muffler onto it if you're set on going the "Type R" route.
You can check out CTR exhausts as they are made for hatch's and may work depending on your setup.
sinfulj32
Feb 24, 2005 07:07 PM
deviant1
Nov 8, 2002 08:32 AM
