D series manifolds
Old Jan 10, 2006 | 07:42 AM
Rmerchant3's Avatar
Default D series manifolds
What do you guys think of this...I am thinking about buying a 88 crx DX with the d15 dual point from a friend of mine for an everday point a to point b car. The motor in it is back fireing out of the intake really bad, and i haven't had a chance to really look into it, but i am willing to bet that it has some valve problems. Anyhow, this is my question. My other friend has a d16 out of a 88 crx si. Is it possible for my to throw that motor in there and just put my intake on it so i won't have to convert to multi-point? I am pretty sure it is possible...but i just wanted to get some imput. thanks.
Old Jan 10, 2006 | 07:45 AM
shadycrx's Avatar
Default Re: D series manifolds (Rmerchant3)
you have to convert to MPFI , search for it there is a faq on it, you use Si intake manifold
Old Jan 10, 2006 | 08:38 AM
kranked91dx's Avatar
Default Re: D series manifolds (shadycrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadycrx &raquo;</TD></TR><TR><TD CLASS="quote">you have to convert to MPFI , search for it there is a faq on it, you use Si intake manifold </TD></TR></TABLE>
FALSE : you dont HAVE to... but then, puttin a d16a6 into that car would be point less... a d16a6 will not perform like it was intended to, knowing you will running it with a dual point fuel injection.
instead, put the d16a6 in there, wire up the car to mpfi and enjoy.
it's really easy... juste search a bit on it before you enterprise anything. you will find a enormous amount of info.
but YES your DPFI manifold will work on the d16a6 head... it's totally stupid to do so, even if it's feaseable....
Kranked.
Old Jan 10, 2006 | 08:42 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rmerchant3 &raquo;</TD></TR><TR><TD CLASS="quote">The motor in it is back fireing out of the intake really bad, and i haven't had a chance to really look into it, but i am willing to bet that it has some valve problems.</TD></TR></TABLE>
Likely has a cam timing problem. I'd look into fixing that before you go trying to swap engines.
Syper
Jun 23, 2011 11:57 AM
donaldmejr
Jul 27, 2006 10:12 AM
thirteen20CRXSi
May 11, 2006 05:26 PM
SPOON_EG6
Dec 9, 2002 04:03 PM
LsTurbo91
Jul 2, 2002 06:14 PM
