alternator problem
Old Jan 10, 2006 | 07:39 AM
00accordguy's Avatar
Default alternator problem
ok. yesterday and this morning when i go to crank my 2000 accord 4 cyl. the battery was dead. ok, so i jump it off, no problem runs good all day except i have a battery and brake light come on. so today i get home and go to charge the battery and find that it has boiled some of the acid out of the battery. not good, so i bring it in to the Napa here in town and they put a battery checker on it, and its good. so i crank it and the reading jumps to 16 volts and starts climbing. so i was wondering, is this a common problem with hondas and is there by any chance a recall or do i have to get my alternator fixed or a new one? any help would be great.
thanks guys
austin
Old Jan 10, 2006 | 08:49 AM
P_Adams's Avatar
Default Re: alternator problem (00accordguy)
Unfortunately, it's not a common enough problem to warrant a recall; but since I've joined this forum, I've discussed this twice.
The alternator (or more precisely the Voltage Regulator) is overcharging, and it will require replacing.
You've been lucky so far. This is normally accompanied by blown bulbs, motors, the occasional ECM, warped battery plates and the rare Hydrogen Gas explosion.
I believe the Denso Alternator can be repaired, and the voltage regulator is available separately. (#19 in supplied linked illustration)
http://www.hondaautomotivepart...SO%29
But you may find that an aftermarket re-man Alternator could well be cheaper.
P
Old Jan 10, 2006 | 09:47 AM
ok, next question, I found a rebuilt one, but it says its for a 4 door sedan, is there a difference becuase i have the 2 door
austin
Old Jan 10, 2006 | 10:25 AM
P_Adams's Avatar
I suspect there are no physical differences between to 2dr/4dr versions, but both honda and an Aftermarket sourse:
http://replacement.autopartswa...=true
call out different Part numbers
Honda:
2000 LX 2dr: 31000-PAA-L71RM
2000 LX 4dr: 31100-PAA-A01RM
Aftermarket: Denso Reman
2000 LX 2dr: FA000-106870
2000 LX 4dr: FA000-106871
P
Old Jan 10, 2006 | 02:32 PM
YeuEmMaiMai's Avatar
Default Re: alternator problem (P_Adams)
one most likely has a higher output
Old Jan 11, 2006 | 02:38 PM
Default Re: alternator problem (YeuEmMaiMai)
but would this cause my battery to go dead?
austin
Old Jan 11, 2006 | 02:42 PM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00accordguy &raquo;</TD></TR><TR><TD CLASS="quote">but would this cause my battery to go dead?
austin</TD></TR></TABLE>
Defective Alternator; YES, definitely!
Higher Output: Definitely not
P
b16_swap
Mar 30, 2011 06:51 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
kuni00
Audio / Security / Video
12
Dec 16, 2004 09:53 AM
ID_ten_T
Nov 2, 2004 11:24 PM
