integra rear brake swap/abs question
i've searched and can't find a definitive answer here, so i'm hoping someone will be willing to help.
I removed the rear from a 94 integra for my brake swap, only thing is that it is/was equipped with ABS. When checking against the faq i noticed that the prop valve only had four inlets, so i'm assuming i'm going to need the prop from a non-abs integra?
Will the prop work from a 90-93 integra or does it have to be from the newer?
I'm sorry for all the lame questions, but my crx has been totalled and i'm hoping to get this hatch somewhat rolling here as soon as possible.
thanks again.
thanks again.
the proportioning valve from the older tegs will work. The bracket that mounts it to the firewall is different but functionally it is the same. All the lines plug into the same place also.
glazedham42
Feb 27, 2006 06:04 AM
glazedham42
