Rear windsheild wiper question...
If I were to get a rear windsheild wiper for my EG Hatch, how would I get it to turn on once it is installed? If possible, I'd like to go all OEM... no custom switches or anything like that.
You can junkyard all of it... you'll need the wiper stalk off the steering column, wiring, I believe it's called the ICM (silver box behind underdash fuse block), and the wiper motor + arm. You would also need the plastic lines for the fluid squirter and maybe a t or something for the wiper fluid resevoir. You might even need the fluid resevoir and a service manual for wiring diagrams, I'm not too sure...
It seems like an awful lot of trouble for a wiper... I've personally thought about getting rid of mine. Good luck either way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DestructoEH »</TD></TR><TR><TD CLASS="quote">You can junkyard all of it... you'll need the wiper stalk off the steering column, wiring, I believe it's called the ICM (silver box behind underdash fuse block), and the wiper motor + arm. You would also need the plastic lines for the fluid squirter and maybe a t or something for the wiper fluid resevoir. You might even need the fluid resevoir and a service manual for wiring diagrams, I'm not too sure...
Thanks, I don't think I'll be doing this anymore... I just thought it'd be an easy plug n' play
</TD></TR></TABLE>Thanks, I don't think I'll be doing this anymore... I just thought it'd be an easy plug n' play
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by besouza »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
Lots of plugging. You could always drop one in without the "squirter" to save some trouble.
.</TD></TR></TABLE>Lots of plugging. You could always drop one in without the "squirter" to save some trouble.
