coolant leak help!!
Old Jan 9, 2006 | 09:23 PM
KURUPTinc's Avatar
Default coolant leak help!!
quick question i noticed my car was leaking massive amounts of coolant, so i went under and noticed that it was coming from a hole in the block next to the oil filter underneath the oil pressure sensor (d16) now i dont know if a sensor goes there or a freeze plug cause it looks like something obviously went there. any one got a pic or an answer?
Old Jan 9, 2006 | 09:41 PM
naptownrex's Avatar
Default Re: coolant leak help!! (KURUPTinc)
I beleive a coolant temp sensor of some sort goes there. I think that the fan receives a signal from this sensor when the coolant reaches a certain temperature. So if the plug was missing, I could easily see coolant leaking from it.
Old Jan 9, 2006 | 09:47 PM
KURUPTinc's Avatar
Default Re: coolant leak help!! (naptownrex)
so you think its the fan switch? can you get like a diagram or something?
Diregraf_Capt
Mar 19, 2014 01:04 AM
theeogflip
Aug 8, 2008 12:05 PM
duneracer69
Jun 14, 2008 03:15 PM
busyychild
May 6, 2008 11:09 AM
JoshM
Jun 2, 2002 06:11 PM
