DPFI to MPFI
Old Jan 9, 2006 | 06:49 PM
Fusion G2 Civic's Avatar
Default DPFI to MPFI
I have the full manifold, do I need the obd0 MPFI ECU? I have the resistor box as well. I have the wiring down also. Will I need a MPFI dizzy or cant I just wire a few things into it...?
Old Jan 9, 2006 | 06:52 PM
rc90hatch's Avatar
Default Re: DPFI to MPFI (Fusion G2 Civic)
use the 88-91 si computer
Old Jan 9, 2006 | 06:53 PM
rc90hatch's Avatar
Default Re: DPFI to MPFI (rc90hatch)
and yes you do need to use a mpfi ecu, i did the same change over as you and i used the 88-91 si computer and manifold from a crx + b16 injectors, and beasted on ls's all day with a sohc non vtec in a 90 civic 4dr
Old Jan 9, 2006 | 07:08 PM
Arent all honda injectors the same?... if not I have some d16z6 injectors I could throw in, will they make any difference. Also what about my dist. can I use my current one? and is there any other kind of ecu i could use. I plan on goin to a junk yard tomorrow and I wanna know what car I can gank one out of...
Old Jan 10, 2006 | 10:55 AM
bump
Old Jan 10, 2006 | 11:12 AM
jlicrx's Avatar
you could use the PG7 ECU from 88-89 (not 86-87) Integra or PS9 from 90-91 Civic EX
Old Jan 10, 2006 | 11:46 AM
AJxr's Avatar
i dont think the z6 injectors will work because they are obd1
Old Jan 10, 2006 | 11:51 AM
vegaskurt's Avatar
Default Re: DPFI to MPFI (AJxr)
there is no difference in between the obd1 and obd2 injectors other than the clips that hold the wires to them. If you use obd1 or 2 then you dont need to wire the resistor box. Each injector gets a ground and a signal.
Old Jan 10, 2006 | 12:42 PM
Mach69's Avatar
Default Re: DPFI to MPFI (vegaskurt)
You must use a MPFI distributor. Which means a 88-91 crx/civic Si one.
You need a obd-0 mpfi ecu, which means pm6 (88-91 crx/civic si ecu) or the pg7 (which i don't recommend)
Not all honda injectors are the same, most flow 240cc and some flow more like 310cc (?). Obd-0 injectors are low voltage while obd1 and obd2 injectors are higher voltage.
Old Jan 10, 2006 | 08:48 PM
Rywire's Avatar
Default Re: DPFI to MPFI (Mach69)
hondas are basically all 240 with some being 190, and 310 i believe. If you want to run high inped. inj. just cut the inj box, and merge the wires.
Old Jan 12, 2006 | 03:32 PM
xisda1's Avatar
Default Re: DPFI to MPFI (jlicrx)
How about a PM8 out of a 88 crx
Old Jan 13, 2006 | 05:32 AM
iTe4LIFe's Avatar
almost all honda injectors are 240cc and preludes above 91 are 320cc. I'm not sure about injectors out of acura's (meaning honda engines from acura's). why not get dsm? I got mine out of a 93 talon for $5.00
Asmooh
May 9, 2009 11:30 AM
B16A CRX
Mar 16, 2007 12:23 PM
Layziebtnh055
May 28, 2004 12:19 PM
s2kkk
Feb 16, 2004 06:22 PM
djhonda
Jul 15, 2002 08:29 PM
