h22a in eg, no spark
Old Jan 9, 2006 | 06:07 PM
makelove2hondas's Avatar
Default h22a in eg, no spark
As the title says i have no spark i was wondering if the ignitors are all the same for hondas or are h22a's different?
Old Jan 9, 2006 | 07:41 PM
SAVIOVEGA's Avatar
Default Re: h22a in eg, no spark (makelove2hondas)
I am currently using an igniter from a d15b7 on my h22. But before you do that, check your coil
Old Jan 10, 2006 | 02:39 AM
Default Re: h22a in eg, no spark (SAVIOVEGA)
coil is all good still no spark and i have checked everything i can think of
Old Jan 10, 2006 | 03:59 AM
kulrevon's Avatar
did your tach act up in anyway before the car died. usually that is a sure fireway to tell if it is your ignitor.
also try turning the key to the on position the check engine light should come on for two seconds then go off. if it doesnt go off it is probably your main relay.
try the second test just in case.
and I believe all the f series ignitors are the same I havent dealt with switching parts between series.
Old Jan 11, 2006 | 02:47 AM
Default Re: h22a in eg, no spark (kulrevon)
does the relay have another name, and where is this main relay located thanks
eagle459
Sep 7, 2008 09:01 PM
mugeneghatchie
May 15, 2008 12:48 PM
jchrm80
Jul 20, 2007 08:13 PM
nudvl
Oct 7, 2005 06:10 PM
