intake manifold question
Old Jan 9, 2006 | 05:17 PM
si0385.'s Avatar
Default intake manifold question
i have a d15b and right now its wired obd0 with a pm6 intake manifold when i wire it obd1 do i need to put the p08 intake manifold back on or can i keep the stock si manifold on it
anybody wired obd1 with a pgm fi manifold and throttle body on the car
Old Jan 9, 2006 | 06:47 PM
Mach69's Avatar
Default Re: intake manifold question (jaydeum4lyfe)
OBD wiring has no affect on the intake manifold, it could care less.
And yes, you can wire the pm6 IM obd-1. Infact, that is my setup. I run a p28 on a z6 engine with a pm6 intake manifold and a bored pm6 throttle body. I run obd-0 injectors with a injector resistor box.
EDIT: since ur in central florida (i got to UCF), you can PM and I can show you my setup.
DarKStaR5
Aug 30, 2011 02:54 PM
Chewy Built !
May 22, 2007 05:16 PM
SupraRXZ
Feb 3, 2006 05:21 PM
