Need Help Adjusting Headlamps
Old Jan 9, 2006 | 03:57 PM
mikec7276's Avatar
Default Need Help Adjusting Headlamps
I have a '94 Honda Accord and am trying to adjust the headllamps. I can find the screw that adjusts the up and down movement of the light but cannot locate the adjustment for the side to side movement. Can you help?
Old Jan 9, 2006 | 04:34 PM
P_Adams's Avatar
Default Re: Need Help Adjusting Headlamps (mikec7276)
This is going to be difficult to discribe without pictures, but I'll give it a try.
Adjustments can be performed with a long shank phillips screwdriver (9" to reach the lower (Side to Side) adjuster)
Adjustments to the left side are easy(er)
Adjustments to the right (lower) require removal of the radiator overflow to gain access.
The bottom adjuster looks like a square box which protrudes out the back of the headlamp near the bottom, almost directly aligned under a 1/2" hole on the top of the Radiator Support. With a flashlight, if you look directly into the top of this, you'll see a toothed wheel. You rotate that wheel in/out using the blades of your Phillips Screwdriver. That adjusts the headlamp side to side..
The top adjuster looks like a 3/8" (head diameter) phillips screw which is mounted horizontally. This adjusts the headlamp up/down
P
Old Jan 9, 2006 | 07:00 PM
Ross 2.0's Avatar
In a Junkyard near you.
That was impressive P. I could have understood that if i was the one that made this post. You brought a tear to my eye. Oh sorry just gas...
But good job anyway.
Old Jan 9, 2006 | 07:10 PM
P_Adams's Avatar
Default Re: (MooGoCow3)
Ross;
Truthfully, was it my post or the Curried Shrimp you had for dinner?
I've often been called "Long Winded" but not THAT way
, LOL
P
ashtonallen
Oct 18, 2015 04:17 AM
scanlessfool
May 18, 2007 12:56 PM
November
Welding / Fabrication
May 16, 2006 06:54 PM
94ls
Jan 29, 2003 06:20 AM
