suspension install
Old Jan 9, 2006 | 03:22 PM
BrokenRex
Guest
Posts: n/a
Default suspension install
I have a front suspension kit, upper controls, inner/outter ties, ball joints. And new shock/coilover kit. Ive never installed suspension before, does anyone have a how-to H-T link or something, I mean I have the basic idea, but I just dont wanna screw up something. Also I work during the day, and I go 2 school 2. You guys think I should just have a shop do it?
Old Jan 9, 2006 | 03:43 PM
crxtreme89h's Avatar
Default Re: suspension install (Br0KeNCRX)
Pick up a Helms, Chiltons, or Haynes manual at your local auto parts store.
Old Jan 9, 2006 | 04:05 PM
Pee Wee's Avatar
Default Re: suspension install (crxtreme89h)
the coilovers are really easy, as for everything else i dont know. for the coilovers all you have to do is remove 4 bolts (per side). 2 on the top hat, 1 on the lca, and 1 that holds the brake line in place.
Old Jan 10, 2006 | 01:42 PM
BrokenRex
Guest
Posts: n/a
I have a front suspension kit, upper controls, inner/outter ties, ball joints, and Omni coilover kit. What else would you suggest that I buy with it, Camber kit ? ? ? ? ?
Old Jan 10, 2006 | 02:57 PM
Pee Wee's Avatar
what about the rear suspension? you will need a camber kit, and since your doing all the other stuff you might as well do the bushings
Old Jan 10, 2006 | 02:58 PM
CRXb18Turbo's Avatar
will you going all out... don't forget the boots/dust cover.
Yes, you'll need a camber kit too. ( but the camber kit is basically a new upper control arm. )
Old Jan 10, 2006 | 03:02 PM
Tyson's Avatar
you dont need a camber kit unless your frame or suspension is bent.
just make sure you get an alignment after you install everything.
Old Jan 10, 2006 | 04:44 PM
BrokenRex
Guest
Posts: n/a
Default Re: suspension install (Tyson)
Well the inside of my tires went bald and there is like 40-50% trend on other side, so i rotated them. I def need an allignment anyway. So tyson would u suggest I get camber kit, and is it hard installing tie rod ends, ball joints???? I got the control arm part down.
Old Jan 10, 2006 | 04:46 PM
Tyson's Avatar
your tires wore out unevenly because you needed an alignment.
why do i need to repeat myself? you dont need a camber kit.
nothings hard to work on on a crx. you just got to do it once to learn. it only gets easier the more times you do it.
Old Jan 10, 2006 | 04:49 PM
BrokenRex
Guest
Posts: n/a
ALSO which handbook is best, chiltons/helms/haynes!??!?!
Old Jan 10, 2006 | 04:52 PM
Tyson's Avatar
helms. no question. dont waste your time using anything else.
Old Jan 10, 2006 | 04:58 PM
BrokenRex
Guest
Posts: n/a
Tyson you are the man Well it seems pop boys/autozone dont have 88 crx manual + I called honda earlier, they dont have it either WTF . . . . where should I get it from online???
Old Jan 10, 2006 | 05:00 PM
Tyson's Avatar
helms manuals are discontinued i think. maybe they sell unbound copies now. original ones pop up on ebay often. $50 was retail, for reference.
but honda.uk provides the whole manual online. keep in mind its for the UK cars, so it also has DOHC ZC engine info.
http://www.honda.co.uk/car/owner/workshop.html
Old Jan 10, 2006 | 05:07 PM
BrokenRex
Guest
Posts: n/a
0000OOooooo snapppp http://www.helminc.com has it I think. Shop/service manual yay!!
Old Jan 10, 2006 | 05:13 PM
BrokenRex
Guest
Posts: n/a
Tyson . . . I can get this Helms manual BUT "Any wiring diagrams in the original shop/service manual are NOT reproduceable and are no longer available." Is there alot of wiring in the original?
Old Jan 10, 2006 | 05:17 PM
Tyson's Avatar
you wont need it. it was a couple fold out diagrams that showed all the wiring circuits. i never referred to it, kinda always got tangled as i flipped through the manual.
sounds like theyre going to send you a quick bound printed copy of the manual. i think i have one of those at home as well. i got like 4 different helms manuals...
Old Jan 10, 2006 | 05:24 PM
BrokenRex
Guest
Posts: n/a
It will still have all the info Id want out of it though??
Old Jan 10, 2006 | 05:35 PM
Tyson's Avatar
youll be fine....
Old Jan 10, 2006 | 06:05 PM
fireant's Avatar
Folks like me will help you out if you are close by, where are you located?
Otherwise, I would say everything is fairly easy to do if you have a Helms manual... I did all mine myself at home. The inner tie rods are the hardest part.
Here's a checklist of essential tools off the top of my head:
___ Jack Stands
___ some blocks of wood for propping and shimming things
___ rented spring compressor from autozone etc.
___ PB-blaster
___ torque wrench
___ breaker bar
___ ball-joint puller of some sort (I can recommend a $5 one that always works)
___ 3-lb sledge
___ 19mm socket and wrench
___ 17mm socket and wrench
___ 14mm deep socket and wrench
___ 12mm socket and wrench
___ 10mm socket and wrench
___ 4" socket extension
___ 7" or 9" socket extension
___ 17mm "crows foot"
___ 45° Dykes (heavy pliers, not lesbians)
___ wire brush, carb cleaner, degreaser, bucket (clean as you go)
___ roll of shop towels (or two)
___ gloves
___ anti-seize
Also, Ingalls camber kits require 15mm and 18mm sockets, if you are using them.
Tyson is right that toe-in or toe-out is the reason your tires wore out on the insides. You can have up to -2 degrees camber and your tires will wear normally if you toe is correctly aligned to zero.
Old Jan 10, 2006 | 06:55 PM
BrokenRex
Guest
Posts: n/a
Default Re: suspension install (fireant)
thats amazing for the top of ur head lol, I wish I lived near someone that could help me out, I live near chicago So I guess ill take it as a learning experience and do it myself, can this be accomplished alone over a weekend ? ? ?
(F-T work/college) . . . . . where to get 5$ balljoint puller? (how much is renting compressor/whats PB-blaster/anti-seize)
xkrntamax
Honda Civic (2006 - 2015)
27
Jun 22, 2009 09:21 AM
defkid999
Jan 23, 2006 12:49 PM
Master23
Dec 8, 2004 04:46 PM
iwhichisme
Jan 27, 2003 02:31 PM
