how much $ to fix heater?
Old Jan 9, 2006 | 03:02 PM
ilovemyaccord's Avatar
Default how much $ to fix heater?
hi my heater and a/c always blows out warm air no matter what temperature i set it to. and when i turn it on, my rpm. i say that because im about 90% sure before when i turned on my a/c or heater, the rpm would jump up a little and you can feel and hear the engine working harder. it no longer does that and the air is no hot or cold.
Old Jan 9, 2006 | 03:26 PM
hondadude's Avatar
Default Re: how much $ to fix heater? (ilovemyaccord)
Do you have any Idea of WHAT KIND OF CAR YOU HAVE ??
Old Jan 9, 2006 | 09:06 PM
Default Re: how much $ to fix heater? (hondadude)
o sorry about that, 2000 accord v6 ex
Old Jan 9, 2006 | 11:36 PM
s13_240sx_92's Avatar
Could just be a cable that got disconnected or it could be much worse. Can't really answer it without seeing the car.
Good Luck
Old Jan 10, 2006 | 04:00 AM
YeuEmMaiMai's Avatar
if your a/c AND heat are no longer working, and the temp is constant, you may have a bad control unit. when you press buttons, do your vents change accordingly? ALso when it is really cold outside, your A/C may not function beacuse will not turn on when the outside temp falls below a certain point.
If the control unit is bad, that is gonna be some serious cash............
Old Jan 10, 2006 | 08:13 AM
if you mean the control unit are all those buttons, then those work right. when i set it to blow alot of air it does that, it just doesnt blow the right temp
Old Jan 10, 2006 | 09:26 AM
amckee's Avatar
Default Re: (ilovemyaccord)
Look up under the dash on the right side of the console where the carpet meets the firewall. Actuate the temperature **** and see if the cable is moving the lever fully or if you have a stripped ****.
Old Jan 11, 2006 | 12:01 PM
Default Re: (amckee)
i looked for the level you were talking abouit but couldnt find it, so i had a friend move the temperature control around and i saw nothing move under there
singlecamslamed
Nov 20, 2016 07:56 AM
ekferio
Nov 3, 2006 06:12 AM
crxtreme89h
Dec 12, 2005 03:17 PM
Echelon
16
Jan 31, 2004 03:56 PM
