repair weather stripping with what?
Old Jan 9, 2006 | 02:28 PM
fleetmack's Avatar
Default repair weather stripping with what?
i ripped my weather stripping near the driver's door rear-view mirror while tinting my windows when i first got my car, but it somehow tore dramatically recently and now my window is whisteling like crazy when it's closed. i need to get this tear fixed...
is it cheaper for me to replace all the weather stipping or is a repair a worthwhile option (meaning, will the repair last)? Can I just use super glue or epoxy or something or is there a special product I can purchase to seal this tear in my weather stripping? The whisteling noise is driving me nucking futs.
Old Jan 9, 2006 | 03:38 PM
hondadude's Avatar
Default Re: repair weather stripping with what? (fleetmack)
The best fix is to get a new window run channel. you'll need to remove the door liner inside to replace it. if you do this replacement you can put some 3M trim glue at the bottom of the run channel to keep it from working up in that front corner
Old Jan 9, 2006 | 03:47 PM
accordselux's Avatar
Me Gusta History
yea hondaautomotiveparts.com, or some honda tech sponsor dealerships will offer you replacement parts at a good discount
Old Jan 9, 2006 | 04:53 PM
amckee's Avatar
I agree with hondadude. Your best bet is to replace it, however, I will share with you a method I have used for years to repair weatherseals and leaky doors, trunks, and moonroofs. You will need Black RTV silicone, methyl alcohol(safer) or laquer thinner(don't drip on paint ) , Saran wrap, Chapstick. Clean the surface of the leaking gasket with alcohol twice to be sure it is clean and degreased. Apply silicone to the area that leaks. How much is dependent on the particular problem. Be very neat and even with your bead. cover the silicone with Saran wrap and close whatever it is you are sealing. On a window I would cover the window in Saran, run Chapstick along the top of the window, and roll it up. Remove the excess that sqeezes out unless it is on an unexposed surface. Leave it overnight or longer if it is very cold before you remove the Saran. By the way, Epoxy and other glues will not stick to something coated in chapstick in case you needed to first glue something down and then repeat the procedure with RTV to form the seal. This may not work for your problem at all. I don't know exactly what it looks like. Years ago I had a 79 Grand Prix that I rebuilt the door seal on this way. Those long doors didn't have a window chanel and the door seal looked like fringes. This method works EXTREMELY well on trunk seals and leaking moonroofs.
VTECwalka
Apr 25, 2013 06:26 AM
jdmpremonition
Aug 13, 2010 06:40 AM
MIKEuBEEZY
May 28, 2008 07:39 PM
yoohoo
Sep 15, 2007 01:23 PM
Shaar
Jul 2, 2007 04:59 AM
