I NEED HELP WITH MY SPEAKERS
Old Jan 9, 2006 | 11:35 AM
LORDNIKON's Avatar
Default I NEED HELP WITH MY SPEAKERS
I HAVE A 88 4DR CIVIC I WANT TO TO PUT 6X9 IN THE REAR DECK HOW Can i install them with out cutting the deck or just give me som ideas on installation
Old Jan 9, 2006 | 11:41 AM
MLD211's Avatar
Default Re: I NEED HELP WITH MY SPEAKERS (LORDNIKON)
Why dont you want to cut the rear deck? If you really want 6x9's pull the rear deck cover cut the holes mount them and put the factory cover back over them. If you have a clearance issue mount the 6x9's from the bottom. Or use the factory speaker size and avoid all the head ache. I for one like 6.5'' speakers. The rounder the speaker the better!
Old Jan 9, 2006 | 11:47 AM
fcm's Avatar
fcm
Old Fart
There is no easy way, and no matter how you end up doing it if you want to take advantage of the 6x9 size you will have to cut the rear deck, the best way would be to replace the cardboard trim, [cover] with a custom cut and fitted 3/4" MDF panel, [lots of work] and mount the 6x9s from the top, that will make the hole you have to cut, [or make bigger] in the rear deck as small as possible, and mounting the 6x9s on the MDF will get the most out of them. 94
weasel_18
Audio / Security / Video
Sep 16, 2014 02:57 PM
EG-SIXV-TEC
Mar 10, 2010 11:06 PM
allhonda
Feb 28, 2008 08:50 AM
dmlpro
Sep 17, 2006 09:24 AM
Jesterian
Sep 29, 2005 01:15 PM
