1990 Accord Speedometor Problem
Old Jan 9, 2006 | 08:46 AM
rleonekc's Avatar
Default 1990 Accord Speedometor Problem
My speedometor, cruise control, and odometor doesn't work. iT sometimes wors but when it does it has very slow reaction.
I was wondering if there was a diagram of some kind i could look at and then look at my car to see if anythings out of place
Old Jan 9, 2006 | 08:52 AM
994TurboCoupe's Avatar
Default Re: 1990 Accord Speedometor Problem (rleonekc)
auto or manual? check speed sensor first, maybe a loose plug
Old Jan 9, 2006 | 09:03 AM
P_Adams's Avatar
If you were to tell us that the "Service Engine" lamp was on, I'd suggest the problem was endemic of a defective VSS (Vehicle Speed Sensor). The signal from this single sensor is supplied, not only to the ECM (Engine Control Module), the TCM (Transmission Control Module (auto) and the Speedometer but also drives the Odometer and the Cruise Control System. Anything which requires knowing how fast the car is traveling.
The "Service Engine" lamp works, right?
I suspect (tentatively) a poor connection either at the cluster, or at the ECM.
If you can think of other things you may have noticed, please relay them. There's not a lot to work with here. Maybe with a few more 'hints'.....
P
EGpurp92
11
Jul 31, 2017 10:01 AM
MIKESY8299
Jun 10, 2016 10:53 AM
anuz
Aug 21, 2013 02:02 PM
drastikstylez
Apr 22, 2008 07:54 AM
rleonekc
Jan 9, 2006 09:32 AM
