rear Defrost
Old Jan 9, 2006 | 07:18 AM
bon3's Avatar
Default rear Defrost
91 accord lx
My rear defrost don't work? Even when you push the button there is no click where the button pushes in. Any ideas?
Old Jan 9, 2006 | 07:20 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: rear Defrost (bon3)
Replace the switch and check the fuse.
Old Jan 9, 2006 | 07:21 AM
honda4674's Avatar
have you cheakd your fuses
Old Jan 9, 2006 | 08:37 AM
bon3's Avatar
Default Re: (honda4674)
Will check the fuse and switch.
How much will a switch cost?
Old Jan 9, 2006 | 09:13 AM
djryan's Avatar
Default Re: (bon3)
If you go to a junk yard you should be able to pick up a switch for under 20 bucks. Hint: if you go to the junkyard, you can tear up their car figuring out how to replace the switch, so when you get to yours....you know what you are doing. On my car you can just use a flathead screwdriver to catch a notch on the bottom of the switch to get it off.
Modified by djryan at 7:45 AM 1/11/2006
Rob.
Nov 1, 2012 12:26 PM
Bludger
Sep 26, 2010 07:57 AM
TegBen
Jul 26, 2004 04:45 AM
CIVIC dude
Jan 9, 2004 10:35 AM
