what is a zc swap?
Old Jan 8, 2006 | 10:54 PM
Koble's Avatar
Default what is a zc swap?
im looking at buying a honda the guy said it had a zc swap... is that a h22? or b18c or what?
Old Jan 8, 2006 | 11:02 PM
91tealhatch's Avatar
Default Re: what is a zc swap? (Koble)
ill be nice, because some pepole will be dicks, everybody need a intro to hondas. a ZC is a D-series motor, meaning it is a single over head cam motor(SOHC) but the ZC also comes in a Dual over head cam version too(DOHC). it is nothing like a H22 or a B18c, those are both vtec, a ZC is not, altho i have herd of a sohc zc vtec, but know nothing about it. the ZC is a good cheep motor, if you blow it up, it is $700 to replace it. when a B18c will cost alot more. well i hope this helps you with your desision.
Old Jan 8, 2006 | 11:11 PM
31flavorscivic's Avatar
Default Re: what is a zc swap? (91tealhatch)
DOHC ZC is 130HP, the others are less HP but I don't know the exact numbers.
Old Jan 8, 2006 | 11:33 PM
xfletcherxx's Avatar
Default Re: what is a zc swap? (31flavorscivic)
SOHC ZC VTEC swap is nice.
My 1995 Civic Coupe w/ D16 SOHC ZC VTEC swap + Ghetto Filter pulled on a CRX w/ DOHC ZC Swap.
So basically, the ZC swap, is either a SOHC Vtec (Maybe some non-vtec? I think they all are.) or a DOHC Non-Vtec. Both of which put out about the same numbers I believe.
Old Jan 8, 2006 | 11:45 PM
Default Re: (DA)
SOHC and DOHC ZC's are both 1.6l.
Old Jan 9, 2006 | 04:46 AM
DEIVIONCRX's Avatar
Default Re: (xfletcherxx)
SOHC ZC Vtec is a 1.6L
SOHC ZC is 1.5L
SOHC ZC Vtec is a 1.5L
DOHC ZC is 1.6L
Brown Top ZC that is DOHC it fits in the 84-87 Civic/CRX/Teg 1.6L
Black top ZC DOHC fits in 88-91 Civic/CRX 1.6L
Black Top ZC DOHC OBD1(Grey plug disturbitor) fits 92-95 Civic/Delsol 1.6L
D16A1 was avaliable in the US it came in the 84-89 Integra's its DOHC 1.6L
all ZC's were not avalible in the US
the DOHC ZC also goes by D16A8 and D16A9 in countrys other than Japan
Old Jan 9, 2006 | 05:13 AM
Twilight's Avatar
Default Re: (DEIVIONCRX)
Nice and friendly input. 8th post and no flames. Weird in Honda-tech! But thats a good thing
Old Jan 9, 2006 | 06:00 AM
thapimpfromchi's Avatar
Default Re: (Twilight)
zc motors are sweet man. they pull hard, and last forever, as with all honda motors. good start for any beginner.
Old Jan 9, 2006 | 10:49 AM
d16vtecx's Avatar
Default Re: (thapimpfromchi)
no zc's were 1.5l
Old Jan 9, 2006 | 11:28 AM
Targa250R's Avatar
be professional
Default Re: (d16vtecx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16vtecx &raquo;</TD></TR><TR><TD CLASS="quote">no zc's were 1.5l</TD></TR></TABLE>
Correct. All engines stamped "ZC" are JDM 1.6L D-series engines. They were avilable in SOHC non-VTEC, DOHC non-VTEC, and SOHC VTEC configurations.
All SOHC VTEC ZCs had PGM-FI multi-point fuel injection and were OBD-1.
Non-VTEC ZCs were available with either dual carburetors or PGM-FI multi-point fuel injection. Non-VTEC PGM-FI ZCs were available with pre-OBD and OBD-1 systems.
Old Jan 9, 2006 | 02:51 PM
DEIVIONCRX's Avatar
Default Re: (Targa250R)
D15b is a SOHC ZC 1.5 Vtec, just isnt marked as a ZC, the d15b version is called a sohc zc by lots of people i just added it cuz theres a plethera of zc
Old Jan 9, 2006 | 03:04 PM
rayzian's Avatar
What kind of tranny do I need to swap a ZC into my 91 DX?
Old Jan 9, 2006 | 03:13 PM
jlicrx's Avatar
Default Re: (rayzian)
your DX transmission will work - not the best choice, but will work - any 88-91 CRX/Civic transmission will work with the right flywheel/clutch combo for the transmission used - a ZC transmission will also work with a ZC intermediate shaft and 90-93 Integra axles
Old Jan 9, 2006 | 03:27 PM
rayzian's Avatar
Default Re: (jlicrx)
Thanks.. I guess that'll be the route I'll go. But when you say it'll work with the right flywheel/clutch combo, what about the stock DX flywheel/clutch?
Old Jan 9, 2006 | 03:31 PM
that will work too. but if ur gonna be swappin out flywheels, u might wanna get a lightweight one. stock flywheels are heavy as ****. if i want pics of a dohc zc, i have one in my sig link. its missing the valve cover. but u can get an idea.
Old Jan 9, 2006 | 03:32 PM
reply, actually, i have alot of zc stuff for sale. lol. if u need anything, just let me know.
Old Jan 9, 2006 | 03:51 PM
godruler's Avatar
the d15b vtec is not a ZC, it does'nt matter if lots of people call it that because thats not what it is, its a d15b. lots of people call their 88-91 civics Ef's even though they are ED's. ZC means 1.6L and nothing else
Old Jan 9, 2006 | 04:47 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEIVIONCRX &raquo;</TD></TR><TR><TD CLASS="quote">D15b is a SOHC ZC 1.5 Vtec, just isnt marked as a ZC, the d15b version is called a sohc zc by lots of people i just added it cuz theres a plethera of zc</TD></TR></TABLE>
Um, no. If it isn't stamped "ZC," then it is not a ZC. That's a pretty easy concept to understand. All engines that are stamped "ZC" are 1.6L. A D15B is not a ZC, it is a D15B.
Old Jan 9, 2006 | 04:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Um, no. If it isn't stamped "ZC," then it is not a ZC. That's a pretty easy concept to understand. All engines that are stamped "ZC" are 1.6L. A D15B is not a ZC, it is a D15B.</TD></TR></TABLE>
d15b would be a dx motor, depending on what number is after that b. ZC is ZC.
i believe someone else mentioned it below, it think its like d16a1, thats the usdm equivalent to the zc, but its not exactly the same. a zc still had more power.
here is a link with some basic ZC info.
http://www.zcspeed.com/swaps/swapinfo.html
Old Jan 9, 2006 | 04:58 PM
boylovecar's Avatar
i rocked a sohc zc for awhile. it was a great motor.
Old Jan 9, 2006 | 05:03 PM
boylovecar's Avatar
also the sohc zc is equivalent to 88-91 si motor but a little more go juce. the dohc zc, i believe, is equivalent to the 86-89 dohc motor but with a little more go juice. i've read that there is a brown top dohc zc that should be avoided, but i can't remember why. may fortune be with you when you choose.
Old Jan 9, 2006 | 06:04 PM
Default Re: what is a zc swap? (boylovecar)
^^^^^^^^the motor mounts are in different places^^^^^^^
Old Jan 9, 2006 | 06:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tealhatch &raquo;</TD></TR><TR><TD CLASS="quote">^^^^^^^^the motor mounts are in different places^^^^^^^</TD></TR></TABLE>
good to know man. i didnt know that was the difference. thanks.
Old Jan 9, 2006 | 07:02 PM
Fusion G2 Civic's Avatar
Arent they from the 80's integra's?
Old Jan 9, 2006 | 07:04 PM
Default Re: what is a zc swap? (Fusion G2 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fusion G2 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Arent they from the 80's integra's?</TD></TR></TABLE>
yea, they are the one u want to stay away from
