HELP !!!! PUT IN CLUTCH KIT AND STILL SLIPS
Old Jan 8, 2006 | 10:12 PM
esokol's Avatar
Default HELP !!!! PUT IN CLUTCH KIT AND STILL SLIPS
I DIDNT GET THE FLYWHEEL RESURFACED IS THAT MY PROBLEM? OR DOES IT TAKE TIME TO WEAR IN SO IT CATCHS ALL THE TIME?
Old Jan 8, 2006 | 10:16 PM
1989CivicSi's Avatar
Default Re: HELP !!!! PUT IN CLUTCH KIT AND STILL SLIPS (esokol)
Are you really punching it with a new clutch? If so, check the manual that came with the clutch kit and check the break-in time. I was under the impression that you need to break in a new clutch before really pushing it to its limits.
Old Jan 8, 2006 | 10:22 PM
esokol's Avatar
i am not punching it, just wanting to get to highway speed
Old Jan 8, 2006 | 10:55 PM
31flavorscivic's Avatar
just resurface the flywheel. It's only $40 bucks. I'm sure it will help too.
Old Jan 8, 2006 | 11:01 PM
esokol's Avatar
its already installed to late for that,, so you think thats what is required? it wont wear in and not slip??
Old Jan 8, 2006 | 11:22 PM
wob's Avatar
wob
was the flywheel glazed at all.. and did u change the rear main seal lately
Old Jan 9, 2006 | 12:12 AM
SD_Lurker's Avatar
HT White Ops
yes you have to resurface your flywheel. your flywheel probably has an uneven surface from your other clutch. why the hell would you do that??
B_Swapped93
Apr 4, 2013 06:30 PM
bank2me
Jun 5, 2011 02:13 PM
AllMotorRandy
Jul 13, 2009 10:49 AM
Vtecme92
Mar 14, 2006 06:20 AM
garados
Oct 31, 2002 08:57 PM
