99 Accord Automatic - Differential Bearing Check?
Old Jan 8, 2006 | 10:03 PM
tyro's Avatar
Default 99 Accord Automatic - Differential Bearing Check?
I've a little transmission leak, perhaps the axle seals.
I couldn't verify the exact location of the leak, I only know that the ATF level was down since last checked.
When I last did a ATF change (3k ago), the drain plug didn't have what I think to be an excessive amount of metal or sludge clinging to it.
I know that if it is indeed the axle seals, my differential carrier bearings may be of the bad sort.
Is there some type of check or test I can perform?
Keep in mind - NO whine, NO slipping, NO blinking D4, NO hard shifting, none of the 'bad tranny' symptoms I've read about.
bigginsUT
Jul 26, 2011 06:39 PM
OldMrAccord
Nov 24, 2010 02:27 PM
