Info needed for f22 auto to h22 manual trans swap
Bare with me this is going to be my first swap. I have searched and got bits and pieces but i am looking for all info. If you don't want or have time to explain can you at least point me in the right direction. Thanks
What all do i need to swap f22 auto to h22 manual? trans, flywheel, clutch, manual ecu......what else?
Hydraulic lines, pedal assemblies, gauges, left axle, clutch master cylinder, clutch slave cylinder. I'd probably change in a new water pump/timing belt on the engine you're swapping in. Check out the motor mounts make sure they're good before you put em in. Depending what year your accord is there is plenty of info on http://www.cb7tuner.com Thats a site for us 90-93 accord tuners.
I'm keeping the f22 and swapping in the h22 manual trans. I need a starter for a manual F22 not H22 right?
vietdragontekx
Sep 18, 2009 01:33 PM
KageOokami
Sep 6, 2006 08:50 AM
AccordDohc
Apr 30, 2004 06:58 PM
