Which ES shifter bushing kit do I need to buy?
I have a B16 in my 91 crx. With a modified linkage. I went to autozone and ordered teh Energy Suspension kit for my crx today, but a friend of mine said that They make different bushing kits for a stock crx and a swapped crx....Is this true? Will the bushing kit I ordered work? If not, How do I order the correct one from autozone?
TIA
TIA
I have the master bushing set from ES on my crx si 91' and didn't have a problem when I ordered my shift linkage from Hasport. All the modified shift linkage are simply shorter in length but the back half that connects to the shifter are the same in 88-91 crx, integras, 94-up del sol's and maybe others but I'm not certain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT »</TD></TR><TR><TD CLASS="quote">So, I should be ok with the kit for my crx?</TD></TR></TABLE>
yes..
yes..
wrong
, if you have b series with linkage you need the bseries bushing set. the one that came in my master set did not fit ,i ordered one for a integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">wrong
, if you have b series with linkage you need the bseries bushing set. the one that came in my master set did not fit ,i ordered one for a integra</TD></TR></TABLE>did you have to order a DA integra kit then?
wrong crx and integra are the same part #...
, if you have b series with linkage you need the bseries bushing set. the one that came in my master set did not fit ,i ordered one for a integra</TD></TR></TABLE>wrong crx and integra are the same part #...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">wrong crx and integra are the same part #...</TD></TR></TABLE>that answers my question then.
WTF, when it comes to the D and B series linkage there is 2 diff part #'s. The front part of the linkage is what makes the difference, while the bushing for the stabilizer bar towards the back of the linkage is the same in both kits.
Here is the kit for the 88-91 civic/crx w/ D series and the one for B series has already been posted. This is to clear up any confusion in case someone else runs across this thread. http://store.summitracing.com/...h.asp
Edit: no matter what i do it wont give me the correct link for the D series bushing kit. Part number is ENS-16-1102R,
Modified by fourthgenhatchB17 at 7:01 AM 1/9/2006
Energy Suspension Manual Transmission Shifter Stabilizer Bushings
Bushing, Transmission Shifter Stabilizer, Polyurethane, Red, Acura/ Honda, Integra/ Civic/ CRX/ Del Sol, Set
there the same..
there the same..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">Energy Suspension Manual Transmission Shifter Stabilizer Bushings
there the same..</TD></TR></TABLE>
Obviously you never taken apart or even seen the D and B linkages.
The part numbers are in fact different. They are off by 1 number at the end. Dont always believe what you read! Those companies tend to not know the proper application.
Dseries # ENS-16-1102R
Bseries# ENS-16-1101R
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">
Bseries# ENS-16-1101R</TD></TR></TABLE>
This man speaks fact. When I ordered the master bushing set for my CRX it came with the shifter bushings for D series shift linkage. I had to buy a Shifter bushing set for an integra to work with my shift linkage. Also if you search there was a thread about this like 2 months ago that included pictures of the differences if you still don't beleive.
1990hondaHF
Aug 10, 2006 07:53 AM
naptownrex
Jan 14, 2005 11:48 AM
jaydm98
10
Jun 10, 2003 04:37 AM
NikoZai
Jul 23, 2002 04:53 PM
