crx zc motor swap
depends on if you mean DOHC ZC or SOHC ZC - some SOHC ZC engines are VTEC, some aren't - all DOHC ZC engines are non-VTEC and they are not like a 1.8 LS and are also not like a 1.6 LS - a ZC is a 1.6 and the DOHC is unique
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">depends on if you mean DOHC ZC or SOHC ZC - some SOHC ZC engines are VTEC, some aren't - all DOHC ZC engines are non-VTEC and they are not like a 1.8 LS and are also not like a 1.6 LS - a ZC is a 1.6 and the DOHC is unique</TD></TR></TABLE>
hey thankz for clearing that up now if i want to swap heads for v tec what heads should i use or should i just keep it the way it is i plan on boosting it with a t3
I have the DOHC zc and there are no other heads that will fit on it to my knowing, but they are good to boost on because of the cast iron block, the internals are good to 250hp and JG Engine Dynamics makes some awsome parts for it.
