pr4 ecu
Old Jan 8, 2006 | 09:43 AM
kevb18crx's Avatar
Default pr4 ecu
this is about my 89 crx (b18b1), when i was talking to a few crx owners about the swap they talked about it might be best to use the pr4 (obd0), why would this be?
Old Jan 8, 2006 | 10:06 AM
NCchris's Avatar
Default Re: pr4 ecu (kevb18crx)
The PR4 ecu has the correct fuel and timing maps to run the 1.8 litre DOHC motor as it was meant to be. The HF ecu was designed to run a 1.5 litre SOHC economy engine. I'll bet you are running lean and have a fuel cut at about 5k. The PR4 will fix that and allow you to wind to 7k. The CRX Si ecu would be better than the HF but neither as good as the PR4.
HTH
chris
Old Jan 8, 2006 | 02:18 PM
kevb18crx's Avatar
well there seems to be hardly any problems with the car. It is supposed to have the integra ecu in.....how can i tell by looking at?
Old Jan 8, 2006 | 02:30 PM
Redline130's Avatar
Default Re: (kevb18crx)
On the side of the ecu, there should be a tag or label that has a bunch of numbers and letters on it. You should see PR4 on that tag.
Old Jan 8, 2006 | 03:40 PM
ahthisguyhere's Avatar
i have a pr5 for my b18a and so which car has a pr4
Old Jan 8, 2006 | 08:29 PM
Redline130's Avatar
Default Re: (ahthisguyhere)
I have never seen or heard of a PR5. All OBD0 and OBD1 (90-93 Integras) B18A's came with PR4's.
Old Jan 8, 2006 | 08:36 PM
crxnj's Avatar
Default Re: (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">I have never seen or heard of a PR5. All OBD0 and OBD1 (90-93 Integras) B18A's came with PR4's.</TD></TR></TABLE>
Pr5 is from a integra ZXI sohc zc,,So that ecu isnt the best for the b18a/b either
Old Jan 8, 2006 | 10:02 PM
court's Avatar
25 Year Member
Default Re: (Mr.speaker)
stock honda maps are pretty much all the same.
on a side note, when I had my eg, I t came stock with a d15b7. I then swapped to a b18b, then later to a b20z. i interchanged the dx ecu(po5?) and the ls ecu(p75?) both had the same fuel cutt off's circa 7k. I found the dx ecu gave me more power on the butt dyno. Later on I saw someones chart, where they showed the difference,and it turned out the dx ecu gave the b series motors +1 hp over the stock ls ecu. trip out.
Right now im running a pr4 in my single cam ef. I am only running it because it was very affordable compared to the prices of pm6's.
don't stress over it homie
Old Jan 8, 2006 | 10:29 PM
runeminaEF9's Avatar
Default Re: (court)
you should be able to pick up a pr4 for fairly cheap though. i know my old DA integra had a b18a1 w/pr4.
98bucket
Jul 22, 2010 09:32 AM
saccord
Oct 6, 2005 04:56 PM
FOMULA91
Jul 18, 2005 01:31 AM
srebik
Jun 5, 2004 10:11 AM
