Honda headlight bulb(s) - totally basic question
I'm helping a friend replace her 2002 Honda Accord Headlamp. I've never touched a Honda before. Does this thing have different bulbs for high and low beam?!?!? I've only ever seen twin filament bulbs.
Any special 'gotchas' about the change (handbook says I have to remove the [expletive deleted] radiator reserve tank
(huh???).
Thanks!
Steve
(huh???).Thanks!
Steve
Yes different bulbs in the High[inboard] and Low[outboard]beams. The reservoir is held in by a plastic bolster on the tank side, wiggle it side to side while pulling up; no big deal, pull the rubber boot out of the way and then you'll see the wire clip that latches in a hook. unhook the wire clip and it will pivot to one side; don't touch the new bulb glass with your fingers.
Best of luck I hope this helps you
Yes this was very helpful, thanks.
Reserve tank was a pig to grip though ...
No wire clip - had to turn bulb through 90 degrees and then extract.
The old 'bulb' had no glass ... nor glass bits visible inside the headlight. Hmmm ....
Much appreciated!
Steve
Much appreciated!
Steve
solar2005
Honda Civic (2001 - 2005)
13
Nov 23, 2009 12:53 PM
