speed sensor???
Old Jan 8, 2006 | 08:35 AM
bon3's Avatar
Default speed sensor???
91 accord lx
Can a speed sensor be the cause and effect of my tranny not being able to shift into overdrive. Because the car seems to shift fine through out all first 3 gears, just that it won't pop into overdrive when going at higher speeds.
Because i experience all the usual causes of blinking green light, speedometer works when it wants, check engine light and engine reving in park or at a stop.
Old Jan 8, 2006 | 08:47 AM
hondadude's Avatar
Default Re: speed sensor??? (bon3)
Pop up the link below and then you'll be able to get the 'flash' code and be able to get a correct diagnose; not wind up throwing money at the problem.
http://members.troublecodes.ne...n.jpg
repost the code and get some more help
Old Jan 8, 2006 | 08:51 AM
YeuEmMaiMai's Avatar
If everything checks out, as strange as this sounds, check this out. It works.
Make sure that you car is reaching proper operating temp. If the car is not at proper operating temp, then the ECU will not allow the TQ coverter to completely lock up.
Old Jan 8, 2006 | 08:58 AM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bon3 &raquo;</TD></TR><TR><TD CLASS="quote">91 accord lx
usual causes of blinking green light, speedometer works when it wants, check engine light and engine revving in park or at a stop.
The VSS can certainly cause those problems, and every one of those conditions point to it as the culprit, but maybe not the only one.
There are two solenoid packs mounted to the transmission case. they have filter screens under them. If these screens should become clogged with debris, OD and Converter lock up could cease functioning. Remove the solenoids, and clean the screens
P
Tank_EM2
Honda Civic (2001 - 2005)
Jul 1, 2014 03:28 PM
janelectric
Aug 27, 2012 06:04 AM
aandDavidsaid
Honda Civic (2006 - 2015)
May 30, 2012 10:57 PM
gjohnson4
Aug 10, 2004 08:13 PM
CaptainObvious
Aug 18, 2003 04:41 PM
