92 accord ex no spark
Old Jan 8, 2006 | 06:40 AM
iluvdrt's Avatar
Default 92 accord ex no spark
OK, so my friend got a 92 accord ex for free, for a daily. It needed some work, and so we put it into the shop. It isnt getting any spark. It had a Viper alrm in it, which I removed thinking that may be the problem. I found that the coil was getting the 12v needed, but it wasnt passing through to the coil and into the ign amplifier. I changed the coil out with a new one, and now everything is getting voltage.
It still has no spark. I checked to make sure the timing belt wasnt broken and it is OK. The dizzy turns fine, and has very minimal shaft play.
I checked the codes on the ecm, and it flashed a "0". In the book it says this is a bad ECM. Is that true?....any other things I may want to check after we change the ecm?
Thanks for the help.
Old Jan 8, 2006 | 07:09 AM
Honda-Master's Avatar
i have seen a lot of failed ignitors....
Old Jan 8, 2006 | 09:13 AM
hondadude's Avatar
Default Re: 92 accord ex no spark (iluvdrt)
This link might help you
http://techauto.tripod.com/s.htm
Be sure there is a good ground at the T-stat housing
The code Flashed '0' ?? Does that mean it just stayed on when the jumper was connected? If so that means 'no code'.
Old Jan 10, 2006 | 07:16 PM
iluvdrt's Avatar
Default Re: 92 accord ex no spark (hondadude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">This link might help you
The code Flashed '0' ?? Does that mean it just stayed on when the jumper was connected? If so that means 'no code'.</TD></TR></TABLE>
Ill be sure to check the ground. As for the code, it stayed lit for a while, than went off...nothing else. It was on maybe for a second.
Old Jan 10, 2006 | 07:33 PM
civicboisi's Avatar
Default Re: (Honda-Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master &raquo;</TD></TR><TR><TD CLASS="quote">i have seen a lot of failed ignitors....</TD></TR></TABLE> that'll be my guess...does it turn over at all?
Old Jan 11, 2006 | 02:42 PM
iluvdrt's Avatar
Default Re: (civicboisi)
Yes, it turns over fine. the timing belts are ok, and everything has voltage going to it. I thought it was the ignitor as well, until I tried to read the ecm codes. The CEL came on for a few seconds and then it never flashed. Now I am thinking that that is code 0...bad ecm, or no codes and it is the ignitor.
Old Jan 11, 2006 | 04:30 PM
zumiez007's Avatar
Default Re: (iluvdrt)
If the CEL isn't on normally, and when you check it for codes, if it doesn't blink, that means that you don't have a code. Not a code zero.
Old Jan 12, 2006 | 04:37 PM
iluvdrt's Avatar
Default Re: (zumiez007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zumiez007 &raquo;</TD></TR><TR><TD CLASS="quote">If the CEL isn't on normally, and when you check it for codes, if it doesn't blink, that means that you don't have a code. Not a code zero.</TD></TR></TABLE>
Than how does it flash "0" to indicate a dead ecm? Does the cell just not come on at all when the jumper wire is placed in the connection?
Old Jan 12, 2006 | 05:53 PM
Dirt Mcgirt's Avatar
i thought a bad ecu was when the cel just stays steady on, with or without the jumper in.
Old Jan 12, 2006 | 11:37 PM
i_kick_turtles's Avatar
Like Dirt Mcgirt said, a bad ecu will keep the cel on constantly. I'm also going with the ignitor theory.
Old Jan 16, 2006 | 04:28 PM
iluvdrt's Avatar
Default Re: (I R Tylor)
Well, I got a new ignitor today...actually a whole distributor, so Ill keep everyone updated if I can get it runnine tommorow.
Old Jan 16, 2006 | 07:33 PM
D16Z6racing's Avatar
Distributors are known to just go out. I had one explode while I was driving on the freeway.
tcyman2718
Jan 27, 2015 07:51 PM
The_Caged_Bird
May 27, 2008 03:58 PM
Lil_Stu07
Dec 21, 2007 02:44 PM
MattPark
Feb 13, 2005 08:04 PM
